LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
Posted on Sep 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Damaged hard disk - LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
Anonymous
Level 3:
  • Master 6,771 Answers
  • Posted on Sep 18, 2012
Anonymous
Master
Level 3:
Answers
6771
Questions
0
Helped
1778870
Points
21413
There is no way to retrieve the data, however there are specialty labs out there that can access information in the majority of cases, but be aware that it will be expensive.
When pc boots My wdc hard disk shows sec master hard disk S.M.A.R.T status bad backup and replace
your hard disk getting damage so take back up fast and replace hard disk with new hard disk smart test when hard disk want when hard disk surface going some hardware problem
tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 • Computers & Internet
Hard disk damaged & this solved prb. plz
You have to replace your hard disk. You cannot repair a damaged hard disk. You can be able to get the stored data using softwares like windows undelete. but you cannot use it again to store any data.
Window gets stuck on "disk
It is clear your hard disk has developed errors.
Let the disk check run completely. If is stops in the middle, that shows their is a major problem with your hard disk.
If you cancel the disk checking, the computer hangs because some of the system files are already damaged due to the hard disk error.
One thing you can do is to backup everything and format the hard disk and reinstall the operating system and the software.
If the hard disk error is propagating type (i.e. the amount damaged keeps increasing), you will have to reinstall the OS every 2 to 4 weeks.
In this case it is better to replace your hard disk.
Error occured in toshiba satelite 1300 in the hard disk code 0101340000
Error code 0101340000, may be due to hardware issues
1. Faulty hard drive or defective memory
2. Damaged recovery media(CD) or faulty CD ROM
OR
Boot system corrupted,
This issue may occur if one or more of the following conditions are true:
The basic input/output system (BIOS) does not detect the hard disk.
The hard disk is damaged.
Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
Note Some third-party programs or disk corruption can damage an MBR.
An incompatible partition is marked as Active.
A partition that contains the MBR is no longer active.
Hope it helps.
Hai sir, my name tirupati, my system hard disk damaged. if formate drive means result is this disk is unable to formate disk is damaged.
Good suggestion is that backup your data and get a new hard and copt that data into new hard drive....
because it the disk is damaged then there is no solution except replacing!
I have a operating system not found
  • The basic input/output system (BIOS) does not detect the hard disk.
  • The hard disk is damaged.
  • Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
  • An incompatible partition is marked as Active.
  • A partition that contains the MBR is no longer active.
Contact your hardware manufacturerYour best bet may be to contact the manufacturer of your computer or your hard disk. The manufacturer may have a utility that you can use to perform a more detailed scan for damaged areas of the disk and help verify the correct BIOS settings. However, be aware that the damage to your hard disk may be serious. Sometimes this means that your only solution is to replace your hard disk.
I dropped my Western digital 1TB hard drive.
The case maybe damage, so could the hard disk.
First try connecting to your computer or to an USB hard drive adapter, if it works then you know the hard drive is OK and you only need to buy a new USB hard drive adapter case.
WinHex is a edit program that allows to you see and modify the data files on the hard disk in ASCII and HEX format. If the hard disk is faulty no programs can access the data on the hard disk.
There are data recovery companies that can recover data from damages/faulty hard disk BUT it will cost you an arm and a leg for their services.
1helpful
2answers
Hard disk is damage what can i do...?
Give it to the authorised service station and claim the warranty. They will backup your data and possibly replace with another HDD. There are many expert technicians who can retrieve data from a HDD even if its damaged.
Top LaCie Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Steve Sweetleaf
Steve Sweetleaf
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
