I can received texts and can make outgoing calls, but when someone tries to call in, it says that the number has either been disconnected or is no longer in service. I verified with Sprint that the account is active and unrestricted. I was told to remove the battery, but that did not work either. Any other ideas?
SOURCE: i cant answer an incoming call, the screen goes black
you need to recalibrate the proximity sensor. this is what stops you from pushing buttons when you are in a call ect. to do this go to main menu > phone settings > proximity calibration. from here you can recalibrate the screen which should fix the problem
SOURCE: env3 suddenly quit receiving calls. Can receive
i encountered it many times in my customers phone ,we fix everything ,signal ,software all of the defects that related to call but no luck..and you know what there is only one solution that we discovered ,change SIM CARD and it will be ok..
i hope it will help..
SOURCE: My AT&T Xenon LG not
Did you ever find a solution to this problem? The exact same thing happened to my friend two days ago. Someone sent them the same message repeatedly, and he can no longer receive any messages, other than multimedia.
