I have a Dean Edge 4 bass and after 20 minutes of playing, it just faded out with some static and quit. I tried 2 brand new batteries and got no output. Opened up the control cavity and all wiring seems to be tight. Every time I put a new battery in it and try it, it will play a few notes at low volume with static and then nothing. Guitar cable is good and amp is good.
SOURCE: Dean edge bass quits
The wiring in the back is so very thin and the circuit board isn't attached to anything but the wires that are attached to it. I found two weak solder joints there and one in the battery compartment (you'll have to remove it to get to the solder joints). I don't know which repair did the job, but it's working for now, anyway. I'd like to replace the tiny wires but there's not enough room in that compartment. I, also, had to replace the 4 bridge screws with larger diameter SS screws months ago as ALL 4 were stripped. Thread too fine for wood that soft. Come on Dean, step it up a notch! The bass plays and sounds great.
