GPX HMTU3234 Shelf System Logo
Posted on Sep 17, 2012
Record player plays too fast - GPX HMTU3234 Shelf System
How get fast or slow speed when record music woice recorder
If the used recorder doesnt provide these filters from default...choose any audio editing app to play with the recorded audio file speed or pitch as u like.
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
1helpful
My vcr tapes play too fast
If I remember correctly, VCR players had three speed settings. SP-short play, LP-Long play, and SLP- Super long play. The vcr is supposed to be able to tell what speed the tape was recorded at, thus playing it back at the correct speed. If your unit has lost the ability to sense the speed the tape was recorded then you will have to set the speed manually, if possible. Other than that I would have to say it's time to get a new vcr.
I lost the remote control, how can rewind the hsv tape. Thanks.
There should be a rewind button on the front of the main unit (usually indicated by either REW or 2 arrows pointing to the left), this should be next to the fast forward (again indicated by either F-FWD or 2 arrows pointing to the right) as well as PLAY and STOP - for the VCR. The only thing you would need the remote for is to set the clock and/or perform setup for the DVD player as well as timer recording. Try a universal remote which will make fast forward, play, stop, record (to VHS) and rewind easier.
3helpful
LG RH278 HDD/DVD Recorder
I have an LG RH278 HDD/DVD Recorder, which was suffering from the problem that it could not play any bought DVD movies, which were previously working fine in that same player. It would however play svcd and DVD+R/-R movie discs.
The solution was to replace the laser tray. I found a new LG DVD BD lens LPC-815 laser tray here: http://www.laser-xh.com/en/?act=showproduct&proid=1147
I bought two for $5.50 each. Shipping was $32 (DHL), all together $45.10 (PayPal fees included). Delivery was fast and accurate within 3 working days (China - Sweden).
3helpful
4answers
Recording Speed
the tascam 414 is a 4 track recording studio which uses standard cassette tapes- meaning they only play in one direction, because the tape is full. The 414 records at double speed so that recording fidelity is increased. When you have made a recording you want to mix you then dub your recording though the outputs into another standard tape recorder or whatever you have available, be it a cd recorder or your PC. So, when you listened to your recording on a standard tape player, you were not only hearing it at half speed but you were only listening to 2 of the 4 tracks. The other tracks would only be heard if you flipped the tape over, and they would be heard running backward. I would have though the 414 had a swich to allow it to also record at standard speed to but I guest it does not.
HP Pavilion dv9000 Web-cam problem!
HP issued the following:
Webcam Fast Recording Patch Release Date: 2007-05-17 Version: 1.00 A
s.gif Description
This package provides a patch for the Webcam for the supported notebook models and operating systems.
PURPOSE: Routine
Fixes
Fixes fast recording issue that occurs with the Webcam in Low Light mode.
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=ob-51291-1&jumpid=reg_R1002_USEN
sp35930
3helpful
Recording radio programs
this is due to a to a bad download or recording
could be the bitrate
and memory
try copying it to you computer to make shure
richard from chicago
Top GPX Audio Players & Recorders Experts
SmartAviator
SmartAviator
 Grubhead
Grubhead
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
