SOURCE: Magic Chef Gas Oven - Heats up slowly and has intermittent gas smell
STOP USING THE OVEN IMMEDIATELY!!! You are not getting enough air to the burners to burn all the fuel. Not only will you have an explosion hazard, you'll have a carbon monoxide hazard either of which will KILL YOU. Read all of the info below before you begin.
You need to clean all the burners and inlets thoroughly. You probably used the oven for a lot of broiling of meats or it is quite old. The deposits are clogging the tubes which gauge the amount of air entering the burners or the burner holes themselves. The burner tubes are generally removable by removing one screw and giggling the units clear. Before taking anything apart, note carefully the positions of any mix plates and scribe small marks between the two surfaces. Use a heavy duty cleaner or WD-40 to loosen grime. Don't use abrasives like Comet. Then wash in mild detergent with hot water and dry. Be sure all burner openings are clear. After assembly, note the color of the flames. They should be about 90% blue along their length from the burner head. If they are not, you didn't finish the job cleanly or you have another problem. If the burners are old, rusty or have irregularly shaped flame holes, replace them.
SOURCE: oven does not heat up
I had the same problem with my magic cheff oven. I had to set the temp at 400 - 500 degrees to get to get an actual oven temp of about 250 degrees. The oven temp sensor checked ok with an ohm meter. Should be around 1100 ohms at room temp. I work in the electronics industry and know capacitors go out of range and dry out with heat and over time so I replaced the 3 or 4 electrolitic capacitors on the timer board. Cost me about $6.00 at Radio Shack and now my oven temp is right on the money. I realize not everyone may want to do this but it worked for me. Better than the $200.00 for a new oven timer control board. I have also found a company's website that fixes these boards for about $89.00 ApplianceTimers.com
SOURCE: SELF CLEANING MAGIC CHEF OVEN BOUGHT 24 YRS AGO
That's fairly typical but I would suggest removing the shelves and cleaning those with oven cleaner if they need it at all.
Expect the door to remain locked for additional hours for safety.
The temperature rises to > 900 degrees F and is necessary to start the catalytic process that consumes the crud.
Sorry I didn't see your message earlier-
SOURCE: How do you light the oven pilot on Magic Chef 31000PAW
open the oven. take out the racks and push on the button plan toward the back and left it out of the oven.
you will see a small orfix appromiate middle of the fire ring. light a match to it. put eveything back.
you in business.
SOURCE: Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
