Most BMWs have a dip stick in the reservoir cap to measure the fluid level of the power steering fluid. We use Agip power steering fluid. There are generally just two types, standard Dextrn/ATF and Power steering fluid. Unless the cap or manual states otherwise, then just put power steering fluid in it.
1. regular anti-freeze with 50/50 water mix for coolant
2. oil is 10W-30 regular or synthetic
3. brake fluid: DOT 3 OR 4 4. automatic transmission fluid: ATF+4
5. differential without trailer towing package: 80W-90. with trailer package, use 75W-140 synthetic lube and (4) ounces of friction modifier 6. Transfer case: Dexron IV or multi-vehicle synthetic ATF
7. power steering: standard power steering fluid.
I'm getting hydralic fluid in my engine oil. I was told that it's coming from my power steering unit. It's a JD 400 tractor/backhoe. Would this be correct?
Pregunta , tienes, el manual de la case 580 ck, donde se muestra el circuito hidrailico de la transmision, si es asi, embiame una foto del circuito o el manual y te puedo apoyar.
