If a wall powered charger is used it could be bad or the connection from it to the unit damaged---happens if the charger is connected/disconnected a lot----same thing can happen if using the lighter plug adapter for charging.
The proper vehicle power cables for the Garmin nuvi 260 are part numbers 010-10723-06 or 010-11478-03. The use of improper cables will cause the nuvi to go into mass storage. You may also want to contact Garmin Support for assistance. http://www.garmin.com/us/support/contact
You will not be able to refasten it yourself. This is a surface mount part and you need a very small tip soldering iron to fix it, plus you ned to know how to modify it so it wont break again. Please see this link:
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
If
your GPS unit powers down before it can fully boot up, the battery will
need to be charged. Please charge the unit with the vehicle power
cable or on a computer for at least three hours. After charging the unit,
it should power on and function normally. If the unit will not charge in
the vehicle, check the fuse in the power cable for the unit and
the power outlet in the vehicle. The nuvi 200 series, 300 series, 600 series, 700
series, 1000 series and the StreetPilot C300 and C500 series do not have user
replaceable batteries. These units must be sent in to a Garmin approved repair
facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved
repair facilities. Raytech is a repair facility for Canadian customers. To repair your device
please contact the specific repair facility for your region. If your device is not
still under the 1 year warranty, there will be a cost associated with the repair of your device.
Based on your description, you are doing it right. You said.... "when i connect it to the car charger it shows the computer sysmbol and starts charging. there is no other usb port on the device" That is correct. It takes about 2-3 hours to fully charge a low battery. There is only a mini USB port on a 260. It's used for charging and downloading updates of software or maps.
I have the same question
