InFocus IN72 Multimedia Projector Logo
Grant Laehr Posted on Sep 15, 2012
In72 blowing fuse
Blowing fuse
2helpful
In72 does not power up. I think that it is a blown fuse. Where is this fuse located
if there are no leds lit on the top, then it's a power supply issue. open it up and check the fuse on the power supply (next to where the cord plugs in). if the fuse is ok, you'll have to replace the power supply. you can get parts from an infocus service center or send it to them to repair. either way, try www.avsolutionsny.com. they're really good.
My infocus in76 projector had a blinking red light then started billowing smoke
replace the lamp and blow the dust out of the projector with canned air. if it still won't light, replace the power supply/ ballast, or send it in for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
1helpful
InFocus IN72 shuts off after 20 min.
internal error. if the lamp looks ok and it doesn't have many hours on it, it might be the power supply. the capacitors dry out and do not supply sufficient voltage. the in72s do have that problem.
2answers
IN72 Projector problem
My understanding when we purchased our IN72 2 years ago is that there wasn't any additional benefit for Cable box using HDMI since the IN72 does not transmit audio so using component cables for cable was optimized enough. We have our DVD player connected via the HDMI only. Possibly the transmission from cable box through an HDMI is not compatible audio is confusing it? hard to say. Cable HD channels look awesome thru the compenent cables, the max for IN72 is 480i anyway.
We've got 35 ft cables for all 3 hdmi, compenent, and that vcr one too and it's worked great.
IN72
Hi TheMull
I also checked and the fuse looked fine , but I thought to myself why not take a chance and replace the fuse as this is a very cheap part , and it worked.
In72 power board
Hi TheMull
I just replaced the fuse on the Powersupply Board and Fixya !
Infucos IN72 projector
Hi Ronnel
This is a common Mainboard failure on a Projector.
The unfortunate thing is that the Mainboard will either have to be repaired or replaced.
IN72
Try using a different cable.
If the response is the same on a different cable , then the Mainboard might be at fault - this machine should still be under warranty and the warranty will cover repairs.
1helpful
4answers
Power not working
I have an infocus lp70+ it turns on and displays an image for about 2 seconds even if you push the menu button, then the bulb powers off and it acts like it overheated. It does this when it is clearly not overheating. Please help me, I can be emailed at [email protected].
Top InFocus Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
