SOURCE: hi I have a gw
Try to unplug the washer and leave it off for a minute. Replug it and see if it will run. Otherwise, check your circuit breaker.
SOURCE: fisher & paykel GW 703-U water flow and the engine sounded choked
sounds like out of balance switch is faulty. does the water start stop start stop then machine beeps. if it does it is most likely out of balance switch.please reply 4 more help
SOURCE: fisher and paykel washing machine becomes
i think that 1 or more suspension rods r faulty. lift the lid and at the front of the machine u will see 2 plastic covers, remove the covers and undo the screws underneath. now lift the front of the hob up gently and u will see the suspension rods. they r easliy replaced. but first see if they havent just popped out. if they have just popped out look at the other 3 and refit to how the others are.if u need more help or u find another problem reply back and i will help u more.good luck
SOURCE: I have just owned a Fisher & Paykel washing
F&P washing machines have a self diagnosis capability. However you have to be able to programme the fault mode and be able to interpret the binery display.
It would be best if you called a tech, because ,although the fault could be a simple one, there is always the chance that a component has failed and caused another to fail as well. (Not uncommon with F&P machines)
If you replace a part it might fail again because of a secondary fault.
An experienced tech will check the machine completely, and replace the part or parts and should warranty the work and parts.
You won't be covered by a warranty if you install the parts yourself..
Probably not what you wanted to hear, but a lot less heartache and stress in the long run...
TIP.. Get quotes for fees, experience and warranty before you commit to a service..
Good luck....Nomess
SOURCE: MY FISHER AND PAYEL GW
I have a Fisher & Paykel GW712 and had same problem and fixed it today the drain pump motor had failed although it worked for 1 full cycle. when I tried to wash a second load the water would not completly clear from the machine I finally replaced the pump and now works correctly the pump is easy to install ensure machine is disconnected from power first
