Not sure what device an sm bus controller driver is for
http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html
http://download.cnet.com/jetway-motherboard-driver/3000-2098_4-163033.html
if these driver packages are not right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name or device drivers
SOURCE: network controller
Have you tried downloading new drivers for your mobo on a different computer and installing them?
SOURCE: Need drivers
Here's the web address for drivers for your motherboard:
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5LD2%20SE
You need the chipset drivers and possibly the Audio and LAN ones, too. There are specific ones for your operating system.
Unless there are serious problems with the motherboard, you don't want to mess around with the BIOS.
Good luck.
Sir
Pls advice me on how to download ethernet controller the PC from the net cause at the moment the sound, internet & other devices is not functioning.
Thanking you
SOURCE: motherboard drivers
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=A8N32-SLI%20Deluxe
find drivers here
SOURCE: I need ethernet controller
1. Go to the following link: http://support.asus.com/download/download.aspx
2. In the "General Download" section, select "Motherboard" from the first drop-down menu.
3. Select "Socket 775" from the second drop-down menu.
4. Select "P5N73-AM" from the third drop-down menu.
5. Click "Search".
6. In the pop-up window, select your operating system, then click "Search".
7.On the next page, click the "+" sign opposite to "Chipset". Download the latest driverversion (version 15.24). This package includes both the SM Bus Controller & Ethernet Controller drivers.
8. Click on "Global (DLM)" opposite to "Download from".
9. Enter the numbers/characters in the displayed image into the text box, then click "Submit".
CNet is nice but doesn't answer the question.
neither does the question xplain what operating system or the device its for or what problems you are havinghttp://download.cnet.com/slimdrivers-fre... it might take some time being a freeware driver solution you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
