solution for 6600 bluetooth and gallery cannot open
step 1) make a jumper (you can see the encircle terminal of bluetooth ic) then assemble the mobile,turn it onstep 2) OPEN FIRST THE GALLERY WITHOUT MEMORY CARD,THEN OPEN ALL THE IMAGES,MUSIC ETC. INSIDE OF YOUR GALLERYstep 3) TIME TO TURN ON YOUR BLUETOOTHstep 4) PUT BACK THE MEMORY CARD AND DO 2 AND 3step 5) then remove the jumper and do step 2,3,4..if still the cannot open again,put the jumper and reheat the bluetooth ic and repeat it step 1,2,3,4.I ..GOOD LUCK TO ALL WANT TO TRY! JUST TRY IT THERE IS NO RISk
If you can't opoen gallery too,Usually its a hardware problem.so to fix the problem are changing bluetooth module itself.or you can reheat first in some case its works.But if you still can open gallery its mean a software problem. Good luck.
the p[hone need to be reformatted try pressing and holding the green button, *, and the number 3 button while the off the press the on key while holding the 3 keys
yez.,, its a hardware problem, you just have to replace the bluetooth module of your phone, or go to a near repair cellshop and ask them to do that,, when you open gallery it only stuck up on opening and when u use your camera, it says temporary overload ryt?? and some application won't work, the only thing is to replace the bluetooth module of your phone
if the gallery is saying opening but it is not oening then fillow the folling steps:-
1>take out your memory card & then switch on. if the gallery is opening after taking out the m.m card then again insert the m.m card & delete unwanted &unnecessary softwares from application manager.
