Everything works all right but the screen, recording, print and custom in the mode dial. When I turn around it jumps from sceene to M and if I turn the camera off, turn around the mode dial to one of the features that isnt working and turn the camera on I get a message saying Mode dial is not in the proper position. Tried many things including reset but didnt work
SOURCE: MODE DIAL IS NOT IN PROPER POSITION
Try turning the mode dial again. It may not have been turned properly.
SOURCE: When you turn it on the screen displays
Something seems to be broken or off between the mode dial and the switch. It also may have broken internal parts.
I have had a camera with a similar problem. It was that the small switch inside was broken, and could not be repaired.
These mode switches can be changed, but will require a digital camera repairman to do such a job. It also could be sold for parts/repair on a site such as Ebay.
SOURCE: Mode Dial and Lens Problems! Nikon Coolpix 4600
i had the same problem try this: tap the outside of the dial lightly while turning the camera on it should basically "pop" right out!!!!!!!!;)
