Camera worked fine and then battery went dead and wont recharge, when installed in the battery charger and plugged in the red LED on the charger just flashes and battery is still dead after 24 hours of charging it.
Battery is so dead camera wont even turn on.
I have the very same problem. i haven't used my camera for a long time though, and now that i took it out to use it the battery was dead so i tried re-charging it. The red light keeps flashing and the battery doesn't get charged no matter how long i let it charge...is there a problem with the battery or the charger?
SOURCE: Battery Dont Charge
jpierre's solution (in another thread) was right on the money. Touch
the positive (+)end of the 9v battery to the positive (+) end of the
camera battery.Leave them touching for a few seconds (10 seconds should
be more thansufficient). Seems these lithium-ion batteries are subject
to a'digital memory.' Subjecting it to a volt surge almost three
timeshigher seems to clear it.
http://www.batteryuniversity.com/parttwo-34.htm
In short, it works like a charm.
SOURCE: My Samsung L73 digital camera will not charge.
Have you recharged the battery many times since you owned it? Did you leave it alone for an extended time and it completely discharged and died? Rechargeable batteries sometimes only last 3 years.
i have the same probleme
Same problem.
it said the battery was low
so i charged it for nearly 5 hours
and it still wont turn on
exactly the same problem .... as described with battery and not charging
I have the same problem, and will probably have to buy a new battery. question is , will it happen again?
My bf and I have the same camera... and we have the same problems as everyone. His battery was dead twice and mine was dead yesterday. I called the customer support and they send me a new battery.
