Posted on Sep 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How select bypass tray - Muratec MFX-1430 Copier
Anonymous
Level 3:
  • Master 622 Answers
  • Posted on Sep 13, 2012
Anonymous
Master
Level 3:
Answers
622
Questions
0
Helped
227370
Points
1525
There are two ways to select the bypass.
One way is from the pc...
This involves selecting to print and then in preferences picking the bypass.
The other method of selecting the bypass is from the copier.
To select the bypass for copying press bypass, press others, press bypass, select paper type and press enter.
MFX 1430 SUPPLIES
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
I can't get the bypass tray to recognize the right size paper. I switched the bypass tray with another machine and the copier will still not recognize the right size paper.
After loading the tray, make sure to select the correct paper type at the control panel.
  1. If the Tray Mode is set to Fully Adjustable, the printer prompts you to set the paper type and size.
    1. If the paper size and type are correct, touch OK.
    2. If the paper size or type are incorrect, change the settings.
      1. To select a sheet size, touch the current size setting. Then from the list, select the size.
      2. To select a paper type, touch the current paper type. Then from the list, select the type.
      3. To save the settings, touch OK.
  2. If no prompt appears when paper is loaded, set the paper type and size.
    1. At the printer control panel, press the Home button.
    2. Touch Device > Paper Trays.
    3. To open the Bypass Tray menu, touch the Bypass Tray icon. It is displayed in the top position, before the numbered trays.
    4. To select a paper or envelope size, touch the current size setting. Then from the list, select a size.
    5. To select a paper type, touch the current paper type. Then from the list, select a paper type.
    6. To save the setting, touch OK.
Any time i try to print with my sharp ar-m205, it automatically reselect bypass tray and give error Check bypass tray: out of paper or misfeed. But the original tray i selected is tray 1 and there is paper...
Make absolutely certain the correct size is specified for the paper in your tray, otherwise your print driver may be locked on selecting from the bypass tray and not set to 'auto select'
I am using a Bizhub C550. I want to print an Illustrator file without maing it a PDF. Once, I was lucky to print 8.5 X 11 file using the Bypass tray. I like rinting through Illustrator ai instead of I
The easiet way is to open all trays and load the bypass and tell the machine you loading 8.5 x 11 on bypass.
You can also set it on any tray within the menu of the copier under paper > then select tray > then change paper tray settings. Usually it is set to auto. but you can change bypass to what ever size you want with respect to the spec of the machine.
Bizhub C350 envelope problem
Load the envelopes in the bypass tray select paper on the copier control panel select by pass tray change tray select normal DO NOT select envelope select custom enter size, on printer preference select envelope tray and print
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Bypass tray locked out for printing
Please the copiers models.The paper tray is selected in the computer.To the Ricoh copiers the by pass cassette selected mannually.
I cannot print from the Stack bypass tray. I have tried many adjustments. This leaves me unable to print envelopes and using letter head. What could be wrong?
First of all select the paper select button for the bypass tray on the control panel after putting envelopes in the tray. It will then say select paper size. Press the RIGHT arrow until COM 10 or executive comes up and the select OK. Then print what you want . You have to look at the printing properties on the driver to make sure you have auto or the bypass tray selected
2helpful
2answers
I have another Kyocere fs-1800. This printer will take the paper from the bypass tray first if I have paper in the bypass tray. If not it will take it from the drawer. I have purchased a fs-4000dn. It...
surf to Kyocera's website, download the latest software for your operating system, once you have the software installed you should be able to set all the options you would like in the printers control panel. such as start.. printers and faxes..... right click printer go to properties for all tray assignments and settings. (this instruction is for windows) bypass must be selected after you select print. hope that helps.
1helpful
Can I print onto 5-1/2 x 14" paper
minumum size for the bypass is 3.5x5.5 and max is 11x17
minimum, for the paper trays is 5.75x8.25 and the max is11.5x16.5
so it should run 5.5x14 in the bypass tray
1 load the paper in the bypass tray
2 in the basics screen touch paper
3 select the button for the bypass tray
4 touch change setting
5 select custom size and program the size
How to print 17 inch paper on Ricoh AP 3800 C
You should just be able to place paper on the tray and then select the bypass tray under "properties", "Paper", then under "tray" select "bypass tray" when printing.
1helpful
3answers
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Top Muratec Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
