Hi, You can get the unlock code for a Nokia 6500-1 from www.unlocking4u.com/nokia-6500-slide/rs6wp9/ at affordable cost with easy unlocking instructions.
12345
SOURCE: Nokia 6500 slide - RESTRICTION CODE
hi,
I have Nokia 6500 Slide locked to UK Orange Network.
IMEI Number is 352027027919833
Kindly help with a Unlock code.
Thanks.
CAISER NOMAAN
yes i can help you. You need a unblock code from your network as you have blocked your phone
MY BROTHER SEND ME NOKIA6500 FROM AUSTRALIA MAKE 3G WHEN I AM USING INDIAN IDEA SIM IT DISPLAYS PHONE RESTRICTED PLEASE SOLVE MY PROBLEM
NARESH CHANDRA UTTRAKHAND INDIA
[email protected]
SOURCE: nokia 6500 slide
Im Mobin 4rm UK and my problem is that I have the Nokia 6500 Slide but it is locked to the network 3.
Can u please help me unlock it mate. My other problem is that I tried to enter another sim in my phone just to see what happens, and it asks me for a 'Restriction Code' what is this?
EMEI Number: 356400026122491
My Email: [email protected]
Thank You.
SOURCE: nokia 6500 slide help i need
PLEASE READ FULL INSTRUCTIONS BEFORE DOING ANYTHING
TRY WITH NO SIM CARD IN THE PHONE
Doing this is at your own risk!
Every code unlocks a certain lock. Code number 7 usually unlocks them all but some phones are 'buggy' and will not accept code 7 at first then use code 1.
Usually you only have to use code 1 or code 7.
#pw+xxxxxxxxxxxxxxx+1#
1. Press ( # ) on your phone
2. To get ( p ) press ( * ) 3 times within 1sec
3. To get ( w ) press ( * ) 4 times within 1sec
4. To get ( + ) press ( * ) 2 times within1sec
5. Enter the 15 digit code
6. To get ( + ) press ( * ) 2 times within 1sec
7. Enter code number
8. Press ( # ) on your phone
Now your phone is unlocked!
If your phone isn?t unlocked after code 1 or code 7 then you have either entered the wrong IMEI or Network. Sometimes there could also be a problem with newer software versions. Then you can try another 'Boxserial' Remember! You have only five tries to enter the right code. After that you will need a cable to unlock your phone. So please, be aware
Phone type: DCT4
IMEI: 352027025104628
Model: 6500
#pw+319926630701132+1#
#pw+702310427045122+2#
#pw+754840072200550+3#
#pw+093433717136641+4#
#pw+199064315752575+5#
#pw+286305406405613+6#
#pw+307016424512121+7#
There is 4 locks on a Nokia DCT4 phone.
Lock 1: MCC+MNC (Network och landsspecific)
Lock 2: GID1 lås (SIM-card typ)
Lock 3: GID2 lås (SIM-card typ)
Lock 4: MSIN lås (SIM-card specific lock)
The generated codes open up one or several locks.
Code 1 open lock 1
Code 2 open lock 2
Code 3 open lock 3
Code 4 open lock 4
Code 5 open lock 1 and lock 2
Code 6 open lock 1 lock 2 and lock 3
Code 7 open lock 1 lock 2, lock 3 and lock 4
Let me know if you have any problem follow these instructions and you should be ok.
I think it needs to be done with no sim card in the phone remember you only get 5 goes after this if its still not unlocked then the only other option is with a lead and unlocking software.
This should solve your problem let me know how you get on ok
This is done at your own risk!
