It always appear that my email or password is incorrect even its my email and password.. i have tried entering other email and password of my friends still its not working..
If i open my phone have a message display that is too many pattern attempt and how can unlocked a PUK code even if dont know it?
Wat the unlock code
Ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: i am using samsung gt
you have to unlock your phone before using it with other networks, try codes from http://www.wickedunlock.com/
SOURCE: how to unlock samsung galaxy y (GT-S5360).to many
I forget my unlock pattern code and now asking the gmail addres
SOURCE: 0000 or 1234 does not work - states incorrect
You must put you headset in pairing mode, prior to trying to pair it with your phone. In order to do it, starting with it turned off, press and hold the power button for some 10 seconds, until the indicator light is alternately flashing in red and blue. It is in pairing mode now. Then, bring your phone close to it, and make its bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (blue light flashing every few seconds).
By the way, If its user guide happens to be missing, or, rather, you need further informations on how to pair it with your phone, feel free to download it from this location.
Regards,
Carlos
SOURCE: can you please tell me how to change my message
without modifying the operating system or installing some kind of additional addon, or app. (of which there are many, the normal android OS does not support custom (not factory) text notification tones.
