Seth Thomas St. Thomas Creations 6006.130 Palermo 1-PC Enhanced Height Elongated Toilet Logo
Posted on Dec 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Seth Thomas clock that needs started
How do I get this puppy rollin? I did start it, but it is running very fast. I don't know how to stop this, and restart correctly
  • 1 more comment
  • kiowanative2 Mar 12, 2009
    Seth Thomas® 12" Round Radio Control Wall Clock, White
    Is there a need to reset this clock to change the hour for daylight savings time? I tried to change but it either runs very fast or just stops.
    Thanks for your help. This is an office clock and it's driving everyone crazy it's not back up on the wall!
  • Anonymous May 04, 2009
    I have set Thomas Magnolia watch. The chimes do not match with time. This is battery operated wall clock. Any idea how to fix it?
  • Anonymous May 11, 2010
    Ok. One more thing, I think this clock has a pendulum doesn't it? I need to know that 1st.
UsedClockPartsdotCom
Level 3:
  • Seth Thomas Master 277 Answers
  • Posted on Feb 24, 2017
Seth Thomas Master
Level 3:
Answers
277
Questions
0
Helped
146884
Points
4536
I would take it to a clock repair shop.
UsedClockParts.com
David Shaub
Level 3:
President:
  • Master 2,994 Answers
  • Posted on Feb 05, 2009
David Shaub
Master
Level 3:
President:
Answers
2994
Questions
Helped
1152531
Points
8370
If it has a pendulum, you need to either lower the weight or adjust the ticker.
2answers
Need to speed up my seth thomas wall mount hand wound clock
Can't Tell From Picture, But If It Has A Pendulem Ajust screw clockwise for faster (screw is last on arm)
1helpful
Manual for Seth Thomas Grandfather clock model # 46978
Hello
I've Seth Thomas Grandfather 46978 clocks' user manual with me. But I don't know how to send it to you. It is in PDF format. The newly hoilsted Fixya site has no facilty to send the manuals to users I thinks. I can't see it nowhere in this iste. OK.
My Seth Thomas radio controlled clock will not reset to the proper time. I've had it for many years, and this is the 1st problem. I changed the battery, I pushed the button for Pacific time ( I'm...
Hi lufberg,
I see you need help with your radio controlled clock.
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1REo5s6T9
I hope this will help.
Thank you for choosing Fixya,
mvincentc
Jul 04, 2011 • Vacuums
1helpful
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • 0helpful
    How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
  • 3
  • 4
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    How to set
    Hello
    How to reset a Seth thomas weather station wall clock
    what do the boxes in the clock desplay mean and also i do not have an outside temp reading on the clock just inside temp and i do not know what all the buttons on the back of the clock mean and hou to use them the clock is a seth thomas sade weather station
    1helpful
    2answers
    Seth Thomas wall clock wont set to time.
    either the battery is weak or the gears inside are stuck and need to be worked with flathead or eyeglass repair screwsdriver.
    Top Seth Thomas Home Experts
    john h
    ADMIN Andrew
    ADMIN Andrew
    Are you a Seth Thomas Home Expert? Answer questions, earn points and help others
