Hi there. I have pressed F2 and gone into the start up mode where I have changed the password. However, when I restart the computer it still will not accept the new password. is it because it still has an old username? how can I change the user or create a new user when I cannot sign on to this machine? thank you
SOURCE: reset username on e442 emachine
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu Safe Mode Enable Boot Logging Start Windows Normally Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator it will prompt you to enter the new password enter the new password and the password is changed hope this helps
Please select an option:
Safe Mode with Networking
Safe Mode with Command Prompt
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Reboot
Return to OS Choices Menu
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
hope this helps
Firstly you can reset windows admin password in safe mode by the following steps,
Step1: You should restart your computer, and keep pressing F8/F2 to enter the Safe mode.
Step2: After enter the safe mode, you can see the default administrator account, just click it to enter the system.
Step3: Open User Account in control panel, pick the account you have forgotten the password to change the password.
Step4: Restart the computer, you will log on with the newly created password or without password.
If the above method can not help you, you can use Smartkey Windows Password Recovery to help you reset windows password, and you can see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.
