How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
How many times the standby light blinks at a time? Number of blinking of standby light with Sony Trinitron CTVs are fault indications. To know more about these blinks, and fault location, get in this site named Electro-help, and pull up older posts there. Try this link, and select the site.
12 blinks of standby light indicates 'Scanrate error'. You must have thorough knowledge in electronics to proceed. Actually, this is not a user repairable fault. it is very skilled work.
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem. You question shows standby light stays On that means TV does not receive power on command from remote. If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution. Thanks.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/ http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
When attempting to turn on the set, the standby light should blink for a a while then stop once the picture comes on. If a problem is detected internally, the standby light should blink in a repeated pattern. Please count the number of blinks that are repeating and we should be able to help.
The key here is the number of blinks of the standby light. This is an internal diagnostic code. Please provvide that count and I should be able to suggest possible fixes.
