I have a used Toshiba 2860. It said to add toner and also said to empty the toner bag. I bought new toner and also emptied and washed out the toner bag. I replaced the toner bag and put the new toner cartridge in. It said it was adding toner; however, it was dumping the toner straight into the toner bag. And it still says I need to add toner and that I need to empty the toner bag.
SOURCE: red replace toner bag symbol on, bag empty
If the waste toner gets too full before replacement, the auger will clog and bind up. That brings the waste out to the bag.
Solution: Just above the waste container is a black rubber boot. Press that repeatedly until it breaks free (it should be springy). Once it moves in and out freely it should release the auger from the switch at the back of the machine which indicates "full bag".
SOURCE: Empty used toner not clearing
you have to go into service mode and reset counter.in your manuel
SOURCE: toshiba estudio 450 Used toner cartridge is empty
replace the ic of toner cart. problem will be solved
Hello
You will have to remove the waste toner bottle, put some cleaning solvent in the bottle and wash the toner out of the bottle.
Please the bottle out to dry before you replace it in the machine.
Regards
I am not sure what you mean by "originl toner" -also, I cannot find anything in the manual about resetting the toner indication -How do I do that?
What do you mean by original toner and how do I reset the toner indication
