Hasbro Star Wars R2 D2 Interactive Astromech Droid Logo
Posted on Sep 12, 2012
MY R2D2 INTERACTIVE ASTROMECH DROID WONT MOVE OR DO ANYTHING. I depressed the wheel lock button and installed new batteries.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 13, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1385
Points
I put new batteries in , turned on the switch and nothing
1 Related Answer
Anonymous
  • 168 Answers
  • Posted on Oct 04, 2010
SOURCE: where can I get instruction
Manuals R2-D2_Industrial_Automoton
I hope helps.
My interactive R2D2 astromech doesn't detect obstacles
If your Interactive R2D2 Astromech droid is not detecting obstacles and crashing into walls, there may be a problem with the sensors or the software.
The sensors on the R2D2 droid are responsible for detecting obstacles in its path and allowing it to navigate around them. If the sensors are faulty or damaged, the droid may not be able to detect obstacles and may crash into them.
The software on the R2D2 droid controls its movements and behavior. If the software is outdated or corrupted, the droid may not be able to properly interpret the sensor data and may behave erratically or unpredictably.
To fix this problem, you will need to diagnose and repair the faulty component. This may require the assistance of a qualified technician, as repairing a complex electronic device like an R2D2 droid can be challenging.
R2 won't move forward on command
Have you checked to make sure his wheels are unlocked? Page 4 of the manual shows you where it is. http://www.hasbro.com/common/instruct/SW_R2-D2_Interactive_Droid.pdf
3answers
My R2D2 interactive juste flash red
hola tengo el mismo problema que tu, cual es la solucion?
Te escribo desde Spain, mi correo [email protected]
gracias
2answers
On the front of the droid there is a red button that lights up when turned on & turns off after a couple of seconds, depress that button to free up the droid. Its called the wheel lock control button. That should free up your R2
1helpful
I purchased a R2D2 droid from Sharper Image before they went under. I am looking for the instruction manual. Do you know where I can find one?
Direct Link:
https://docs.google.com/viewer?a=v&pid=explorer&chrome=true&srcid=0B9RnqaHtO4WWZTJjNjNkYzEtYTMxMi00NGY1LWI4YjctOTNjZDY1N2JiOTU4&hl=en
Needing a replacement sensor pod for R2D2 head.
I would try online auction places(such as ebay),toy stores,collectible stores,antique dealers,and places like kijiji or craigslist.
Hope this helps.
Top Hasbro Toys Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
