2008 Toyota RAV4 Logo
Posted on Dec 25, 2008
How to hook up the sirius stratus 5 radio in my 2008 rav4?
I have a SAT/AM button on my JBL stereo in my 2008 Rav4.
I have rec'd a sirius stratus 5 satellite radio as a gift this morning.
How do i connect it the easiest way without using the AUX option? Or do i have to use the AUX option and the SAT/AM button means nothing?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
598
Points
I have sirius installed in my 2008 RAV4 JBL system.
There is an adapter made by VAIS technologies http://www.vaistech.com/ that is called a soundlink. It comes with instructions for the connection. The Sirius radio is hidden in this installation, and is controlled by your JBL system. The antenna runs up the side of the windshield (hidden behind the plastic moulding) and mounts to the top right corner of the roof.
HOWEVER- you will not have the full funcionality of the Stratus 5 radio- which has more funtionality that the JBL system can control. Also, the Scrolling feature on the Stratus 5 screen does not work on the JBL display. . . you get the first 15 or so characters, with no scrolling.
I love having an integrated satelite radio in my car, but I do miss the better screen, and the pause feature I had on my sportster (in my old car). Good Luck.
1helpful
Radio works, but no sound. Speakers work fine for Bluetooth.
Sounds like the stereo is still on I phone mode,is there a source button ?Should be able to scroll through to radio mode with that button,what brand stereo,does it have a cd player? does that work ?
What does the glove box hydraulic damper hook to (upper) on 2008 Rav4
Should just clip on tabs. One on side of glovebox and 1 inside dash
1helpful
How to remove audio system 6 disc JBL system in Toyota Rav4 2006
remove the cover in the center of the dash and there will be approx. 8 10mm bolts holding it take them out and undo the wiring harnesses in the back, you may also have to take out the temp controls underneath the radio, depends on the model
2008 RAV4: How do I reset service for RAV4?...
key off press and hold trip meter reset button then turn key to on
5helpful
How do I reset the maintneance required light on a 2008 RAV4
Select the trip odometer A first, then: hold down the trip button while the car is off, turn the key to the on position without turning on the car, then continue to hold down the button for another 5 seconds
Remove radio
Replace the CD player. To pull the plastic baffle off the dashboard: Adjust the heating vents so they point downwards. Grab the plastic bar between the heating vents and the stereo. Pull. Remove the screws from the front of the mounting brackets. Pull out the crappy stereo. Unplug the antenna and the wiring harnesses. Transfer the mounting brackets to your new stereo. Cut off the big wiring harness (unless you're lucky enough to have a replacement stereo that accepts the same kind). Connect the wires to the wires on your new stereo's harness. For more info: check the website: http://tomclegg.net/toyotastereo
Sirius Radio
did you get anthing on this.. If so, please email me at [email protected] I have the same problem.
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
