Bios shows a variety of information depending on setup ultimately ending with, Missing Operating System. Its shown "please select boot device" giving me option to boot from HDD PM ST .....or USB:PNY 2.0FD, its tried to boot from the atheros modem cable, F2 runs setup, ESC opens BBS popup, F9 shoes either "image recovery" or will show restore..etc, but then ends up at Missing OS. when I use the "press alt F2 to execute ASUS Flash it looks for usb, will attempt to read "file 1015PE.ROM" but doesnt see it. bios shows DDRII-667/CL5 single channel mode, Initializing USB controllers....Done, then 2039MB ok (installed memory size:2048) USB Device (s) :1 storage device, Auto-Detecting Pri Master.. IDE Hard Disk Pri Master: ST92500315AS 0003SDM1 Ultra DMA Mode 5, S.M.A.R.T. Capable and status, Hard Disk Locked...enter password etc, which I set up to give me options. Ive tried every Fkey, and other keys, even the pause...noticing that it would allow me time, ..there is a flash to a different bios screen before ending up at Missing OS, but its to fast for me to read it. I just want to try and recover this netbook. send help, please and thank you
SOURCE: Recurring issue: KGPE-D16 opteron 2-CPU "USB
If its forcing a shutdown of the entire machine, I think it may be protecting itself from a voltage issue. What do you have plugged into your USB ports? It sounds like it has detected a voltage problem coming from one of the devices connected to one of its USB ports or something near it and to ensure that the motherboard doesn't get fried its shutting the computer down.
The message is telling you that its detected a device that is over the allowable amount of electrical current and is protecting itself from electrical failure. It could be a problem with the USB jumpers on the motherboard that connect the front usb ports. You might try unplugging these connectors and try to boot up the machine. Leave them unplugged and boot up the machine, if you still get the error after that, it may be a grounding issue with the motherboard mounts that anchor the motherboard to your computer case. If you have any extra mounts underneath the board that you aren't actually using but are coming in contact with the board, you may have to remove them, which would probably involve removing the motherboard from the case.
Get a second set of dual channel RAM from somewhere and test it in the slots and see if it still gives you the same error code. But most likely it will and you'll need to RMA the motherboard as the RAM slots are most likely BAD.
Testimonial: "Thanks mate..I tested it again with another new set of ram but same problem ...Have sent of a warranty claim.Thanks for yor help..Cheers.Ron"
SOURCE: PCI bus 4, device 0, function 0 missing driver
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it or you might have to download them rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html it might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions http://download.cnet.com/drivermax/3000-18513_4-10572602.html Windows 2000/XP/Vista/7/8 free driver program http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html Windows XP/2003/Vista/Server 2008/7/8 free drivers http://www.innovative-sol.com/drivermax/
they will automatically search for and find the correct driver
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
you might have to try a few times to get it right
free program, paid update available
hope it helps
