Tried to connect with blu ray dvd to get netflix on my tv
The only other thing that comes to mind is to check b/g/n network type. The mismatch can make the network access an issue. Make sure that the BR Player is capable of a wireless access in the same flavor.
Unplug the router for 10 seconds and again plug in. Sometimes a simple
restart can resolve network problems on a Belkin router.
Disable the "Windows Firewall," which might be preventing an outgoing
connection. Click the "Start" menu, type "Windows Firewall" and press
"Enter." Click "Turn Windows Firewall on or off." Click on "Off." Click
"OK."
Make sure the router is connected properly to your modem with an Ethernet cable via the router's "WAN" port on the back.
Follow the simple steps to set up the Belkin wireless router
If you need any kind of technical assistance, you can contact support cell at http://www.vtechsquad.com
SOURCE: Blue Ray connection to Belkin G router
your wireless router is encrypted. To remove encryption, go in your computers web browser:
http://192.168.0.1
That will take you to your LAN Administrator.
Follow the simple wireless setup for an unsecured connection or setup your blue ray connection and create your own passphrase or WEPKey.
Hope that helped!
SOURCE: How do I hook up a DVD/TV to my Belkin wireless
Netflix sends free dvd's out for streaming devices.
SOURCE: Im having trouble connecting my
BLU RAY :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the BLU RAY
Step 7: Get the IP Address of the BLU RAY
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the BLU RAY in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
