My trufalt rca sdtv will not leave from the blue screen. i keep going into menu to auto search and it searches but cable still won't come back on. it all started from me trying to switch from tv to av so daughter could play bratz game. well i can't it back on from blue screen, i have comcast cable.
SOURCE: rca 32v432t tv plays,turnsoff,turnson, and stays in autochannel search mode
your going to need to do a resolder of dry looking solder jobs and or poor solder jobs
this could also be your front control board , try disconnecting it and see if the tv stays on
it is possible that the sensor has gone bad or the crystal needs to be replace or worse the EEPROM
my rca 27 in was doing the same thing , i resoldered the board and it worked great for 7 months
so do a resolder of all suspicious solder and heated components
then let me know what happens
also what is your model # for your rca tv ?
also one of rca's kits for repair is some solder and paste , so that should tell you something in its self about rca repairs ( the solder with the paste is supposed to make it handel heat better )
please give a fixya rating so that if you need more help in your tv , I can continue to help you further , thanks
electech
SOURCE: 27F520T RCA Truflat, won't scan for channels, auto or manual, only blue screen, no channels on tv
You need to replace the microprocessor. GoodLuck there is 52 pins to unsolder and resolder a new one. The price for the chip may bee about $35
SOURCE: new comcast analog box code search for disney princess tv
Hey there.... I had the same problem today. I finally figured it out. MEMOREX. I'm pretty sure it was the second code listed,10463
