This is actually a problem with the recovery disk. Your notebook comes with a recovery partition that will allow you to perform a recovery without discs. I would suggest you hold "0" when you power on the computer, and then follow the prompts. You can as well call the Toshiba support for assistance.
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
What does this mean?
What should I do after using the 0 function doesn't work? That's what I tried first and the error popped up mid-recovery. Should I order a recovery disk?
