Hello.im ronald from the philippines. my zr 800 is not working. i turned it on and this symbol appears - well it shaped like a camera with 'offf' at the middle and it is color red. i checked the manual and this symbol is not stated. well the gadget does not record nor does it play.in a record more the lcd functions but all the knobs, the joystick and the record button does not function. hope you can help me with this problem.
SOURCE: Flashing red icon
It must be the internal battery problem. Change the button cell that is located near the charging input jack.
SOURCE: can't get my Cannon zr 90 to work, there's a flashing red light in viewer
yes, I found the manual downloads on Canon's webpage. I wish I could figure out how to transfer my tape videos to a computer. I bought the $50,00 DV-1394 cord and nothing happens--computer doesn't recognize the camera.
SOURCE: Recording stopped working
Beleive the CCD has stopped responding. A cheap way to verify this is to point an infrared remote towards the lens and press a key. This will usually provoke a response from the camera even if all else fails, barring a bad pickup device...accordianman
SOURCE: no video records w/ no LCD in camera mode, yet works in PLAY mode
You may have a mechanicle problem. what you should do is call canon.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
The flash icon appears in the upper left corner of display or it appears as circled flash icon? If flash is open and appears a circled icon, then there’s a malfunction contact that don’t communicate to the camera that the flash is open. Your camera needs service! Be sure the upper part of the flash is unfolded, pointing directly in front of the camera (not downward), because the sensor is just in this second folder. If the icon is not circled, press the right arrow until only the lightning symbol appears (forced flash). Try a shot! If the flash doesn’t pops, then your camera needs servicing (burned or broken lamp or other malfunctions).
