Model is ftf2140eso, when the start button is pressed, the start button flashes, when you hit the start button again, the door locks but no water starts to enter the machine. After 20 seconds, all light go off then the machine starts to beep and all of the lights on the right side flash every 5 seconds. I've unplugged the machine to try to reset it. The only thing my wife did was clean the rubber gasket with a towel.
I've read in a product review that Frigidaire put out a service bulletin regarding the electronic timer circuit board in these machines. Apparently enough of these boards failed to prompt a factory response. With this in mind, you should call an appliance repair center and ask them if they're aware of this Factory Service Bulletin. In many cases like this, where a part is manufactured defective, the repair could be free to you.
Pressed the start button and the lights on the far right fash and then the system shuts down
We have the same problem, when pressing the start button - all of the lights just flash and beep and then stop. I have tried re-setting the power, no change. Verrrryyyyy frustrating!!!
when you hit the start button no water enters the machine and it doesn't start
Don't know what it means to power down/or up?
can't get unlocked to get towels out & get machine running again
just got a new WMEF 963 machine in the manual it says that I should give it an AUTO CLEAN by holding down a button for 5 seconds did this but I can never get it to land on CLE symbol and it does not say what the dial should be set to when trying this could you help ?
plummbers had unplugged for quite awhile, we check water line but the machine comes on for second the lid locked become unlock and water not going in like it should, is there a reset button
