Sears Craftsman Convertible 25cc 2 Cycle Curved Shaft Weedwacker Gas Trimmer Logo
Posted on Sep 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Edger blade quit turning on convertible weedwacker
Was working fine then the blade on the edger attachment quit turning
Dave
Level 2:
New Friend:
  • Expert 101 Answers
  • Posted on Oct 16, 2013
Dave
Expert
Level 2:
New Friend:
Answers
101
Questions
0
Helped
46435
Points
147
One of 2 things...drive cable broken or clutch spring broken
Troybilt 516 Edger blade doesn't turn when engine is working
I have TB2726 Troy 2 cycle 25cc engine with trimmer and edger attachments. The Edger blade stop rotating, it seem that the shaft collar of the edger is not engaging the shaft of the engine. What is the cause and how can it be repaired. It is under warranty.
Jun 20, 2017 • Garden
1helpful
Powerhead runs but tools (blower, trimmer. edger) won't work.
Hi Jim Kamph...
You have a broken drive cable inside of the trimmer.You will need to replace the drive cable
Please rate me
Bud
remove and inspect blade for damage. if all is well check flex shaft conection, may have damaged the inner flex shaft or the ends to the flex shaft
2answers
Change an edger blade
Start here to find User's Manual. Sometimes the nut/bolt holding the blade on is a Left Hand thread and requires CW turning to loosen and remove. Not sure on this model.
Unable to get nut off of a craftsman convertible edger.
Lock on the blade with a pair of ViseGrip Pliers, then try turning the nut, they are installed quite tight, also try clockwise, maybe left hand nut.
Ryobi 775r edger blade does not turn. Motor runs
Have you made sure the drive shaft cable is tuning and is properly installed and that there is no debris or dirt stopping the blade from turning?
1helpful
The motor want turn the attachments i.e. string on the trimmer or blade on the edger
there is definitely a problem in the drive shaft. check to make sure there's nothing blocking the mal and female ends. if there is, clean it out and lubricate it so that the male will attach to the female slot. also check to see that both ends are not stripped. if the motor portion of it is stripped, which most liekly is out culprit, then it needs to be replaced, or you need to get a new trimmer. if you do, i recommend the Ryobi model CS26 gas trimmer.if the atachment shaft is stripped, the the attachment needs replacement. if you replace the motor portion you need not lubricate the attatchment slot. if the attachment is stripped, it needs to be replaced, but im quite sure the female end in the motor shaft is our problem. it could also be broken inside the shaft. make sure nothing falls out if you hold the attatching ends to the ground.
Weedwacker
the problem is the spindle may snap
Top Sears Garden Experts
john h
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Sears Garden Expert? Answer questions, earn points and help others
