Zenith H36F46DT 36" TV Logo
DEBI BOWMAN Posted on Apr 15, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Picture is dark
WE can not brighten up the picture - shows with dark back ground is very hard to see.
Simpson Neal
Level 2:
Novelist:
Champion:
  • Expert 236 Answers
  • Posted on Apr 23, 2007
Simpson Neal
Expert
Level 2:
Novelist:
Champion:
Answers
236
Questions
Helped
82488
Points
343
Your set may need to have a screen control adjustment. This adjustment is on the high voltage transformer and the back cover will have to be removed a access it. I'm assuming that your set has a picture tube in it- not a plasma or LCD display. If this is the case you can remove the back cover and adjust this control while observing the picture being shown. If you adjust it too high you'll get retrace lines (fine lines going accross the screen). If you're not comfortable doing this or inexperienced, you might want to get a technician to adjust it for you. There are dangerous voltages inside! Stargazer
Dark picture,can't get it to brighten up with menu color settings.
Assuming brightness and contrast (picture on some sets) does not help it could be a number of things, how old is this set?
1helpful
My pictures are to dark
if you are doing flash photography you will have to limit the shots to a distance of 10-15 feet to get nicely lit pics. also try setting the exposure compensation to +2 to brighten up the pic. Also are you shooting on manual ???
I have a proview lcd screen and it palys the tv shows in back ground but it's a dark screen like dark blue no picture. Volume and everything working but just no picture. What can i do.
Show a torch light on the screen for a distance, and if you can see the picture, the backlight is not lighting up. Check for its settings on the remote, if you have that option. Check also the settings of brightness/contrast/sharpness/color. If you still have problems, please call in a qualified service technician.
The Picture on my HD-52G886 Model is really kind of dark I can still see the picture and sound is fine but a little to Dark when I try to brighten it then its really dull white.
Changing the contrast will also help brighten your screen. For best results, try changing the contrast and the brightness, to find the perfect combination for your needs.
Picture is dark when taking it at night.
Hello did you try brightening the frame rate of the camera?? and the quality of the picture?? That usualy would help..
Camera is dark
when i go to take a picture or a video it comes out dark. you can't hardly see the person i took the
picture too. It's very fustrating not knowing how to fix the matter. all those buttons are not helpng at all. Can i get any suggestions on how i can make the pictures come out brighter?
Picture is dark
sitnlisten - yes it does appear your pix tube is getting weak,but we may be able to turn up the flyback alittle to brighten up the picture.If you take the back off you will see the flyback-large black unit with a wire going to the round rubber cap on the back of the pix tube.Look at the flyback there are usually 2 adjusters one marked focus the other screen,just turn up the screen a little bit at a time.If you turn this up too much you will wind up with retrace lines on the screen.You may also want to check the pcboard ass'y for a sub bright adjust,and same thing small adjustments.If this don't help your pix tube may be too far gone.I hope this helps. cooltek Feb.1/08
The picture is dark
Hi This could be one of three possibilities, one the High Voltage Screen Adjustment is off, Two the Picture Tube is Weak, or Three there is a problem with the Video Drive Amp/Amps, these are things that should be checked or adjusted by a qualified technician, especially the High Voltage Screen Adjustment, hope this helps.
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
