Posted on Sep 10, 2012
Canon Image class mf4412 error code e202-0002
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 02, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
10163
Points
10
Imageclass mf 4412 e 202-0002
5 Related Answers
Joe Fine
  • 628 Answers
  • Posted on Dec 10, 2008
SOURCE: canon copier image class D760 / system error E0003
Try this one from Canon:
Issue: ERROR LCD: System Error E003
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
Anonymous
  • 685 Answers
  • Posted on Feb 13, 2009
SOURCE: system error 197 on my canon color image class mf 8180
means you need to refill the toner
Anonymous
  • 92 Answers
  • Posted on Jul 27, 2009
SOURCE: canon image class mf5750 legal size paper
Hi ...
If you wish to print using a paper size which is different from the normal one A4, you need to specify the same to the printer else it will not recognize or will not accept the paper ...
Below are the steps that you can follow to:
1) Specify paper size
2) Specify paper type ..
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Please vote if this helps ... Cheers :)
pineworks
Clive
  • 4362 Answers
  • Posted on Apr 28, 2010
SOURCE: system error e225
Canon imageCLASS MF4150 And ERROR E225 maybe others
Canon imageCLASS MF4150 Firmware Update V062 Windows 2000/XP/Vista/Windows 7(all x32/x64) from Canon Multifunction .
Hi there
This is because you need to update your Firmware,
So what I have don for you I have found the Update you need and I have put it on my website for you to download, this is a update for Vista / Win 7 / All 32Bit and 64 Bit.
Click Link = http://www.4all2sell.com/driver/Canon-MF4150_FirmwareUpdateTool_V062.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website is only there foe a limited time.
Anonymous
  • 1219 Answers
  • Posted on Jan 19, 2010
SOURCE: canon image class copier
Internal Components 2
Subject:
Prevention of blank image (modifying the shape of the laser shutter and applying grease to the laser shutter arm)
Detail:
<Symptom>
Since the laser shutter [1] is not opened when the toner cartridge is inserted into the machine, a blank image is output in
some cases.
[1] Laser shutter
[2] Laser shutter arm
<Cause>
When the toner cartridge is inserted, the laser shutter arm [2] pushes down on the laser shutter [1]. In case that the arm has
a scratch on its sliding surface, however, it is caught in the area [3] where the arm comes into contact with the shutter,
preventing the shutter from being opened.
Service Bulletin LBP-FAX/LBP-MFP
HARDWARE
Issued by Canon Europa N.V.
MF6500-014 Rev. 3
(2/4)
[A] View of the closed laser shutter [1] Laser shutter
[B] View of the opened laser shutter [2] Laser shutter arm
[3] Area where the arm is caught
<Factory measures>
a. Modifying the shape of the laser shutter
Modify the shape of the laser shutter so as to prevent the shutter from being caught when the laser shutter arm pushes it
(A turnback is added to the edge of the area that contacts the laser shutter arm).
P-3 Laser shutter [A] Old type
[B] New type
b. Applying grease to the laser shutter arm
To decrease the sliding resistance of the contacting surface (P-2 [3]) of the laser shutter arm and laser shutter, apply grease
to the laser shutter arm.
P-4 Laser shutter arm [1] Grease application area
MF6500-014 Rev. 3
(3/4)
c. Changing the shape of the laser shutter arm and applying grease to it.
To decrease the sliding resistance of the contacting surface of the laser shutter arm and laser shutter, change the shape of
the laser shutter arm. Additionally, apply grease to the arm.
P-5 Laser shutter arm [1] View of the rib in the new position
[A] Old type [2] View of the new shape of rib
[B] New type [3] View of the arm from which the rib is removed
d. Discontinuing application of grease to the laser shutter arm.
It was confirmed that the new shape of the laser shutter and laser shutter arm do not need lubrication by grease for normal
operation. From this, application of grease is discontinued.
Service Work:
When the foregoing symptom occurs, replace the laser shutter with the new type. In addition, remove the laser shutter arm
and apply a rice-grain sized amount of grease (PERMALUB G No. 2); about 30mg) evenly to the area [1] shown in P-4.
As for a machine having one of the serial numbers listed in “Affected Machines” below as “machines for which the shape
change of the laser shutter is carried out”, only application of grease is required: there is no need to replace the laser
shutter arm because the new type shutter has already been mounted onto them.
When replacing with the new type of laser shutter arm, there is no need to apply grease to it.
Service Parts:
No. Part No. Part Name Q’ty Stock Compatibility
Available
from Fig. No.
O FC6-7328-000 SHUTTER, LASER 1 > 0 1 N FC6-7328-020 SHUTTER, LASER 0 > 1 DC NY In stock 102
2 ON CK-055 1-020 LUBE, PERMALUB G NO. 2 0 > 1 F In stock -
3 ON FFCC66--77333311--000200 AARRMM,, SSHHUUTTTTEERR,, LLAASSEERR 10 >> 01 DC YN In stock 102
Affected Machines:
- Machines for which the shape change of the laser shutter is carried out
LaserBase MF6530 EU1 SNF50048 and later
LaserBase MF6550 EU1 SNG50009 and later
i-SENSYS MF6530 EU1 BAC02001 and later
i-SENSYS MF6550 EU1 DAC02001 and later
LaserBase MF6540PL EU1 SNP50288 and later
LaserBase MF6560PL EU1 SNQ50001 and later
LaserBase MF6580PL EU1 SNR21266 and later
i-SENSYS MF6540PL EU1 EAC02001 and later
i-SENSYS MF6560PL EU1 FAC02001 and later
i-SENSYS MF6580PL EU1 GAC02001 and later
LaserBase MF6530 EU2 SNX50504 and later
LaserBase MF6550 EU2 SPB50568 and later
LaserBase MF6540PL EU2 SPC50196 and later
LaserBase MF6560PL EU2 SPD50012 and later
LaserBase MF6580PL EU2 SPF50288 and later
LaserBase MF6550 EU3 SPG50312 and later
MF6500-014 Rev. 3
(4/4)
LaserBase MF6560PL EU3 SPH50444 and later
LaserBase MF6580PL EU3 SPJ50384 and later
i-SENSYS MF6530 EU2 HAC02001 and later
i-SENSYS MF6550 EU2 NAC02001 and later
i-SENSYS MF6540PL EU2 PAC02001 and later
i-SENSYS MF6560PL EU2 QAC02001 and later
i-SENSYS MF6580PL EU2 SAC02001 and later
i-SENSYS MF6550 EU3 VAC02001 and later
i-SENSYS MF6560PL EU3 WAC02001 and later
i-SENSYS MF6580PL EU3 XAC02001 and later
- Machines for which both the shape change of the laser shutter and application of grease to the laser shutter arm is carried out
i-SENSYS MF6530 EU1 BAC02945 and later
i-SENSYS MF6550 EU1 DAC02865 and later
i-SENSYS MF6540PL EU1 EAC04003 and later
i-SENSYS MF6560PL EU1 FAC03073 and later
i-SENSYS MF6580PL EU1 GAC02833 and later
i-SENSYS MF6530 EU2 HAC02049 and later
i-SENSYS MF6550 EU2 NAC03737 and later
i-SENSYS MF6540PL EU2 PAC02633 and later
i-SENSYS MF6560PL EU2 QAC03593 and later
i-SENSYS MF6580PL EU2 SAC02105 and later
i-SENSYS MF6550 EU3 VAC03185 and later
i-SENSYS MF6560PL EU3 WAC02665 and later
i-SENSYS MF6580PL EU3 XAC03025 and later
- Machines for which the following are carried out: change of the laser shutter shape, applicatin of grease to the laser
shutter arm, and change of the laser shutter arm shape
- Machines for which the following is carried out: discontinuance of application of grease to the laser shutter arm
i-SENSYS MF6530 EU1 BAC02946 and later
i-SENSYS MF6550 EU1 DAC03161 and later
i-SENSYS MF6530 EU2 HAC02121 and later
E202-0002 what is problem
Check this link and the answer that they finally found was their problem - hopefully it helps you - Boots66
http://forums.usa.canon.com/t5/Printer-Multifunction-Support/Canon-MF4412-laser-printer-error-quot-turn-the-main-power-on/td-p/40847
ok guys finaly i have found reason for this .
FK3-1153-000---- CONTACT IMAGE SENSOR ASS\'Y , I mean to say this lamp and strip was faulty ,We have replaced it and
printer is now functional...
This error means you scanner is not going back to starting position which is the left side of the glas. Open your scanner and clean & lubricate rail, it might also be off alignment try to gentle move it back to starting position. If you still get the error once swithed on then your sensor might be broke
Blank page printing from canon image class mf4412
Could be many things. Check the drum make sure its turning ,or the corrona wire . this is in the toner cartrage.
21helpful
2answers
2helpful
Canon image class mf4412 error code 301-0001
good affternoon i want the salution of canon printer 301-0001 eror
old marine
old marine
ZJ Limited
ZJ Limited
