SOURCE: harmon kardon avr 25 ii
I upgraded my HK AVR 20II and ran into the same problem when I tried to hook the old unit up out in my garage.
Luckily I remember that on the rear there is a pre-out RCA port (L/R) and a Main-In port that are intended to be to/from an equalizer/amplifier. These come jumpered out of the box, but I had been using an equalizer so the jumpers were long lost.
Assuming you also have no amp/eq you are using, just connect the Pre-Out to the Main-In using a standard M/M RCA cable and you will be in business. (turn the volume down first!)
Good luck.
SOURCE: Harmon Kardon AVR 630
I ever had this problem, so I contact the service center and they re-program all setting. So,would you like to ask the nearest service center.
SOURCE: harmon kardon avr 25 II
hey i also had this problem, i don't know the name of these but they are basically plugs that you have to block output from the front rear and center speakers of the white/red cables... sry for bad description but its on the left side when looking at the back of the receiver, while all of the other speaker wires should be hooked up to the right with the twisting knobs... it took me forever to find this out but yeah it was a simple fix
SOURCE: harmon kardon avr 125 shuts down
CHECK YOUR WIRING!!! I have had problems from time to time, generally after re-arranging, and have found speaker wires slightly touching on 1 channel caused my AVR to give similar problems. GOOD LUCK!!!
Try hooking up a yellow video wire from the back of the AVR 225 Monitor out. Should be at the end of the 7 or 8 yellow video ports on the back of the stereo. Next plug the other end into a yellow video in on a t.v. Get your remote, (Harmon/Kardon) and make sure the t.v. is on the correct video input and hit the OSD(on screen display) button on your harmon remote. There should be a setting in there that says VFD under ADVANCED menu option that allows for turning the front of your stereo lights on and off and dimming them half way also. OFF/HALF/FULL are the 3 options I believe.
If this doesnt solve it your display may have crapped out on you.
