Refrigerators Logo
Anonymous Posted on Sep 09, 2012
Refrigerator door seal has gap, and the alarm keeps going off
The door alarm on my one-and-a-half-year-old Samsung French door refrigerator keeps going off. From the front, it looks like the doors aren't aligning properly. When I stood on a chair and looked at the door seal from the top surface, I can see that the rubber seal on the left door has a gap about three inches long near where the doors meet. If I push on the door hard the alarm stops going off, but the gap is still there. The doors never really looked like they were aligned properly from the start, but I haven't had this problem until now. Thanks for your help!
2answers
Door alarm on brand new Dacor Refrigerator will not turn off
The cupboard panels are not allowing the door to fully compress the seal.
Or if it is this one, contact the seller under warranty
https://www.dacor.com/us/products/refrigeration/french-door-refrigeration/42-inch-built-in-french-door-panel-ready-drf425300ap/
The alert ding goes constantly and no doors are ajar
How do I use the digital control panel on my Samsung fridge ...
www.samsung.com/uk/support/skp/faq/1023129
Samsung ElectronicsFeb 17, 2015 - Energy Saver Button. For better energy efficiency press the Energy Saver button. If condensation occurs on the doors turn the Energy Saver ...
Support - 4-Door Flex Refrigerator ... - Samsung
www.samsung.com > ... > French Door
Samsung Electronics4-Door French Door Chef Collection Refrigerator. 4-Door ... Will the Water Dispenser on the French Door Refrigerator Work Without a Water Filter Installed?
My New Samsung Fridge Won't Quit Beeping - eHow
www.ehow.com > Home
Remove bulky food items that might keep the door ajar. ... Samsung refrigeratorsfeature an internal door alarm system to alert you when a door ... The alarm turns off and the beeping stops no matter how long the doors remain ... Therefore you hear thedoor alarm go off in intervals, even though the door is actually closed.
Samsung french door freezer will not open
Aha!
The Samsung wants the password.... in French! No!
Sorry.... couldn't resist....
If it's iced up then that would hold it shut until it melts.
Icing up is usually caused by a bad seal!
2helpful
Samsung French door fridge is making an intermittent "whooshing" noise. It's still cooling and making ice and I don't see any frost or standing water in the fridge. Any thoughts or advice would be a
These fridges go through all sorts of cycles, the defrost cycle is probably the noisiest, strange sounds are ok, it will tell you when something serious is wrong, alerts & alarms.
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Samsun cool'n'cool the temp for the freezer keeps going up and down and beeping every 20 mins. I tried turning off and on cleaning around the air vents at the back and it still keeps doing it.. any...
you could try cleaning the door seals if there is a gap the seal will not close and the system will keep trying to freeze, anything can stop the magnetic door seals from closing properly, setting of the alarm over time.
3answers
The left side door has dropped and the piece that closes the gap between the two doors will not operate properly. It leaves the gap open and the refrigerator looses coolness. Need to know how to realign...
Check the lower hinge of that door for a broken closer cam. The upper hinge is adjustable and adjusting the corners in the front will shift the cabinet to align the door also.
Eric
6helpful
2answers
Kitchen aid open door sensor alarm keeps going off door is closed
Open door and turn power off then on twice. Then press the Overtemp reset.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
