SOURCE: Will start the wash cycle and DL come on and light
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
Thank you !!
SOURCE: Our washing machine was stopping at various stages
Although the machine itself is balanced, it sounds like the drum isn't. Since it's not held in place with belts, it has a tendency to float some and on occasion, it will become unbalanced. You will notice it more often on lighter loads than heavy because the extra weight of the clothes is enough to seat the drum well enough to run. It's the lighter loads when you will notice an issue. What I've done is to physically lift the drum slightly and shake it around in all directions. After letting it come to a rest in the center, it should balance and run correctly for all loads.
SOURCE: The lid will not lock.
you cant bypass this switch by pushing w/ screwdriver. its a magnetic reed switch open the top deck (3 screws behind the console) inside should be a tech ref sheet quite helpful trouble shoooter in ther
SOURCE: the load finished on my
you need to replace the lid lock. the latch probably broke in 2, and the broken part is whats keeping the lid closed. if you have clothes inside you can open the top by using a putty knife to release the front clips holding the top of the machine down. push each clip in and lift up. you will also be able to access the lid lock this way.
cabrio washer lid lock flashing and won't finish cycle
