Tried to connect again the supply for main board and disconnect the supply for the inverter board of back light. and turn on the tv, if the indicator stay the inventer board was the cause of voltage drop at the power supply board.
SOURCE: i have and olevia 26 in tv..when i try powering
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Cpacitors are less than a buck a piece typically if you order online from a place like www.digikey.com plus shipping, and they usually arrive next business day.
SOURCE: Olevia Kolin PT-501 LCOS TV Screen remains black and lights flutuate
I have the same TV and had the exact same problem. I had to replace the lamp and power supply in mine to get it to work. Unfortunately...its next to impossible to find the parts, at least the power supply. I found the lamp online and I was lucky to get the online store I purchased the TV from to send me a power supply from one of thier stocked models, but only after I turned them into the FTC Consumer Protection. The TV was sold to me as a closeout but new, as it turned out the tv was a refurb, thats the only way I could get the parts I needed.
Hope this helps and if you need any other information please let me know.
T
SOURCE: My Olevia LT37HVS 37' was working fine all day and turned to black screen.
It is either the fluorescent backlight source for the LCD panel or its associated power supply failing.
