Sewing Machines Logo
SewUnique Posted on Sep 08, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Juki DDL-227 won't spin
I have a Juki DDL-227 and it was recently moved to my house. Before it was moved it worked fine. Now when I press the foot pedal the piece that turns the belt will spin, but it won't catch and turn the belt that connects from the motor to the sewing machine. The hand wheel doesnt move at all. Do I need some oil? Is it a special type of motor oil? Any ideas on what's wrong? This is for a project I need to finish today.
sylviaivie
Level 3:
  • Juki Master 1,564 Answers
  • Posted on Sep 19, 2012
sylviaivie
Juki Master
Level 3:
Answers
1564
Questions
Helped
425814
Points
3583
:) welcome to the world of industrial machines. The good news is they are typically simple machines.
It is a good habit to take a few minutes to clean and oil your machine before you start sewing. Look for the oil points and give it one drop of quality sewing machine oil in each port.
Now let's try to determine why the hand wheel isn't turning. Loosen and remove the belt from the large reducer wheel under the table to the sewing machine. Try to turn the hand wheel. If it does turn.... Good! If it doesn't turn... we know the problem is in the the machine head and not the wheels below.
Make sure there is no bobbin thread or upper thread. Try to turn the hand wheel again. Anything?
Look carefully at the machine... is the take up lever bent? (personally had this happen with friends helped me move a big machine like this.)
Keep working this way... inspecting the machine until you find the problem. Good luck
5 Related Answers
Anonymous
  • 208 Answers
  • Posted on Jun 17, 2009
SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
ken dourof
  • 980 Answers
  • Posted on Jun 19, 2010
SOURCE: Toyota 2260 sewing machine. When I press the foot
Chances are you have a small piece of thread stuck in the raceway, turn the balance wheel bac kwards and you may free it off otherwise take out the bobbin and bobbin case and the raceway if you have the type with a drop down gate and clear it.
Anonymous
  • 2777 Answers
  • Posted on Nov 09, 2010
SOURCE: Hi I have a Babylock
So you can turn the wheel manually but the same wheel that turns manually does not turn with the foot pedal. But when you press the foot pedal you hear the motor engage and move / rotate? If so then the motor assembly has a problem on your sewing machine...
Please confirm the scenario I wrote here is in fact what is going on with your machine.
Just reply to my answer here and I can help.
Thanks,
Tim
ken dourof
  • 980 Answers
  • Posted on Sep 01, 2011
SOURCE: Hand week will not turn, when I press foot pedal
Sounds like you may thread jammed in the raceway, take out the bobbin case and raceway and have a good look
Tally Girl
Tally Girl
  • 1134 Answers
  • Posted on Sep 07, 2011
SOURCE: My singer 1120 sewing machine
I presume that you have checked that the clutch to wind bobbins is reengaged?? It is easy to forget sometimes. If your machine has a knob inside the flywheel to do this, then just check that it is fully tighted back up to reenage the motor drive.
Otherwise it may just be the drive belt has worn/broke/is slipping internally. I wouldn't dump it just yet, it may well be repairable.
The motor belt is available here http://www.sewingpartsonline.com/motor-belt-singer-007156xxl5.aspx so if parts are on the market then it may well be worth taking it to a repair shop and getting a quote to fix it. Depends on how long you've had the machine and what you paid for it and the cost to repair vs buying a new one.
If you or someone you know is technical, they may want to have a go at opening up the case and seeing what is happening around the drive/flywheel area - just make sure everything is disconnected from the power first.
I have a juki DDL-8700, I've recently been having problems with it. When I use the knee lift for the pressure foot, the tension does not go back to normal. The machine could be work fine the when I use the...
Check the tension unit, when you use your knee press a pin should open the tension discs then return to normal, check for any fluff in the discs as well
1helpful
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
The race and needle of my Juki 8300N is jammed. There was a thread caught but it's gone as far as I can tell now. The needle won't move even if I turn the wheel by hand - it can just barely jiggle...
douche the hook with oil wait a day and use hand force to get machine to turn. u have thread deep inside hook and its binding the machine. u can spray with wd-40 too but use alot and let it sit.
2answers
Hi, I have a Juki ddl 552 that does not have te stich setting nob. I am wondring how can I change my stich seting? please help.
Here is a threading diagram for this industrial machine
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_552_553_555_227_Threading_Diagram.htm
You can also buy a manual here
http://www.sewusa.com/Sewing_Machine_Manuals/Juki_Manuals/Juki_Industrial_Sewing_Machine_Manuals/227-552-553-555_Instruction_Manual.htm for this model.
I would have thought there would be some sort of screw or adjustment to control stitch length but I can't find an image for your model.
However this image might help, http://www.johnharbsew.com/images/threading/JUKI-DNU-241-TD.jpg, my Singer 20U, has a dial like this with numbers on that you adjust for length, is there something similar on the Juki?
4helpful
3answers
3helpful
2answers
Manual for Juki DDL 227
I Need Manual for Juki DDL 227 Can You Give me
[email protected]
thank you
1helpful
3answers
How to adjust the stich lenght on a juki ddl 553 strite stich.
I still don't understand this. I have acquiured a juki DDL 553 recently to discover I have no idea how to change the stitch length and that there is no reverse stitch. I have pressed the black button and have tried to turn the side?( the wheel?) but when i push down on the black button there is no way to turn the wheel it doesn't move, maybe there is some other part I'm supposed to be moving??
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
