Philips Magnavox Learning Universal Remote Logo
Anonymous Posted on Sep 08, 2012
How do i change the source on my philips magnavox with out the remote?
A freind of mind gave me this 32 inch philip magnavox 32hf5335d/27b, with out the remote. for some reason i cant change the source. i think its set on video.
Abctay.com
Level 3:
Master:
  • Philips Master 372 Answers
  • Posted on Sep 05, 2018
Abctay.com
Philips Master
Level 3:
Master:
Answers
372
Questions
Helped
212080
Points
1385
Just reconfigure a remote control.
This website has many kinds of tv remotes
https://www.abctay.com/tv-remote-controls-c-66_4
5 Related Answers
Anonymous
  • Posted on Feb 14, 2008
SOURCE: Philips Magnanox Universal Remote CL034
I found this website and it has the codes for everything for your universal remote. Good Luck.
http://www.universal-remote.net/philipsmagnavox.html
guest10
  • Posted on Jun 06, 2008
SOURCE: philips universal remote control cl034
hey i tried this and it worked. hold code search till the light stays lit(it may take a couple of secs ) then after its lit press tv and then keep pressing channel up or down till the channel on your tv changes when does press mute to save the code. also the power button will work to during code search , but i use channel because if you accidentally skip your code you can go back the other way. you might need to take out the batteries then re-insert to reset any previous codes. hope this works for you guys as well.
Anonymous
  • 10 Answers
  • Posted on Jan 21, 2009
SOURCE: Remote Control Code for Magnavox mdv-430 dvd player
Yes, a Philips replacement remote should be an excellent choice for your Magnavox DVD player, since they are sister companies. I am using the inexpensive Philips URC US2-PH5DSS and it works well. Your Philips remote will come with a page with all manufacturer codes listed by the type of device. Or you can visit the Philips URC code lookup website at www.urc.philips.com.
The codes listed for Magnavox DVD players are:
0441, 0442, 0447, 0599, 0799, 0699, 0247, 0193, 0093, 0598 You'll have to try them one at a time to see which works best for your player's functions.
Anonymous
  • Posted on Jul 06, 2009
SOURCE: Code
NEED THE CODE OF SONY TV. AND CABLE BOX MOTOROLA
Anonymous
  • Posted on Oct 19, 2009
SOURCE: Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
1helpful
I have a U-verse remote and have tried both codes for Philips and Magnavox and none of them work..volume doesn't work and power key doesn't turn TV off..What do I do ?
Get a Logitech Harmony remote. It programs from their website so if ever you change TV's or any other Hi Fi component, you simply connect the remote to a USB port on your PC and reprogram it to operate the new equipment. It never gets obsolete and will operate several hundred different devices. You can use it to replace several remotes so one remote will operate the whole sound system, TV, DVD players,Audio amps and satellite receivers.
Just curious as to how much a philips magnavox motherboard would cost for a 32 inch tv.. installation included
Need the model number of the set to even begin to answer your question since there are so many different Phillips 32 inch models and they all have different components and circuit board designs.
I need the remote code can't find it i have a dish network universal any help would be appreciated.
We would be happy to help you with that. Here is a list ofcodes that should address your DISH Network remote to your Philips Magnavox DVD Recorder: 801, 766, 556, and 585.
Press and hold the DVD/VCR button located on the top of the remote until allthe mode buttons at the top of the remote light up, then release. Use thenumber buttons to enter one of the codes for your Philips Magnavox DVD Recorder, then pressthe pound (#) button. If the code entered is valid for the remote, the modelight flashes three times.To check that the code works try several different functions on the remote tomake sure it will properly operate your Philips Magnavox DVD Recorder. Keep in mind that somecodes may not be compatible with your equipment. If this is the case, try the other codes listed for that device until you find one that iscompatible with your equipment. We hope this helps and thank you forbeing a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
2answers
3helpful
Change input source for philips magnavox
use the up/down channel until you get to the input you have connected. You did not say you had a remote so i am using the standard fix for this.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
I can't see my tv
You likely need to select channel three or four on the TV itself if you have any kind of box between you and the signal source (cable, antenna, satellite). Magnavox is a name owned previously by Philips and now by Funai. They may not have all the info from Magnavox and Philips but you could check their website to see if they have the instruction manual for download.
Look under 'Support'
Funai
Philips/Magnavox 32MF605W/17 32" LCD Wide Screen HDTV ready w/ATSC.
Yes you can. This TV has both VGA-In and component in support. The only thing you need to change is the input you're using with your remote control. As easy as changing the channel!
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
