Televison & Video Logo
Lucia Purser Posted on Dec 24, 2008
I have a "craig" tv and the word factory is on the upper left corner, when this word appears i can no longer use any buttons on my tv, how do i fix this?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
295
Points
Have a "craig" tv and the word factory is on the upper left corner, when this word appears i can no longer use any
Do I remove the word Factory from My Craig Television old type tv not digital or flat screen.
The set is in service mode state. You have to exit this mode; to vanish the display "Factory". You should have its remote control to do this. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
tip
Viewsonic n1930 factory reset
One year and 3 days after purchase, my Viewsonic TV went gray after turning it on. After doing the obvious (unplugging the power, playing with the buttons, checking the manual), I called the customer support center. A very nice lady gave me the secret to the factory reset.
Hold down the "on" button, the "menu "button, and the "ch +" button at the same time for about 8-10 seconds. Upon release, a menu screen will appear in the upper left corner. Use the menu button on the remote to change the settings. It may take a bit of experimenting. For example, change "off" to "on", or "disable" to "enable". You'll know what I mean when you see it.
Write this hint down and save it - you'll need it. I have to reset my TV every 2 months
on Aug 01, 2010 • Televison & Video
2answers
32" (31 1/2" diagonal, 176* ultra wide, PC input is stuck on the upper left corner of my T.V., How do i get off the T.V. screen for good?
i had the same problem in a sharp tv 32". on the remote control there was a view mode button, i changed the mode and the pc input label in the left upper corner gone
Can anyone offer any suggestions on how to delete/remove titles displaying in the upper left hand corner of my TV screen and right hand corner? For example, if I am watching a program on CITY, the title...
I believe the "Caption Vision" is selected. By pressing the "Display" button on the remote it should toggle through the choices until "Display Off" appears. That should be all.
4helpful
3answers
Cannot remove tv guide banner from Sony bravia 52'
Click on the display button (upper left corner) as a short term fix - it will turn it off immediately - not sure of how to permanently solve this though.
1helpful
Tv is locked,,need help
Hold down the "display" button on TV remote for 3-5 seconds. It will take out of lock mode.
Audiosonic TV - Word "Factory" appears on top left corner
Try pressing the RETURN button (above the DISP button - number 6 on the button list in the manual). The button has two arrows chasing each other. It worked for me on our Audiosonic KMC TH68 TV.
2answers
Audiosonic Tv
Try hitting the RETURN button - that is the one with two arrows chasing each other just above the DISP button. This turned off the FACTORY text on my Audiosonic KMC TH68.
Top Craig Televison & Video Experts
Paul Bade
 Grubhead
Grubhead
john h
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
