We moved recently but there was no problem with the laptops finding the wireless connection but the kodak 7250 printer keeps saying that it can't print and it shows an error of 105-10003. I have restarted the computer, turned the printer off and then back on and have turned the router off and then back on. When I search for wireless connections on the printer it comes up with the same one that we have but it still won't connect.
If the printer is not connecting to the wireless router, you need to address that problem first. It wasn't clear from your problem description whether or not that is the case. If the printer is getting a successful wifi connection then you may need to delete the printer from your PC and re-add it.
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
SOURCE: I have 1 desktop USb connected to ESP3, 1 desktop
Install McAfee Virus Software, It will Automatically fit it with McAfee Easy Web which is part of their software, it's all free through ATT Yahoo downloads.
SOURCE: My kodak ESP 7250 printer
This is one of the common connectivity issues marring the benefits of having a wireless printer. In this situation your printer will not print when connected wirelessly but would need you to set it up with your system using a USB cable. Try resetting the IP of your system to what is mentioned in the printer and in case there is a router connecting your printer and system then use the IP address of router and put it in your system. This should help you fix this printer issue.
SOURCE: connect another laptop to my wireless kodak printer but it won't recognise the printer
check the website of your printer such as if its a Lexmark go to lexmark.com and see if the model number is compatable with the Vista programming. A lot of printers do not operate with Vista. I have three printers that only operate with XP and Windows 7
