FRIDGIDARE GALLERY DOUBLE ELECTRONIC OVEN
MY WIFE DECIDED TO CLEAN TOP OVEN BUT TRY AND COOK IN BOTTOM OVEN AND NOW THE TOP OVEN DOOR IS LOCKED (I CAN FEEL NO HEAT AROUND DOOR) F8 CODE IS FLASHING AND OVEN IS BEEPING
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Oven Control Beeps
and Displays an "F"
Error Code
Electronic control has detected a fault condition. Push CANCEL pad to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
number, push the CANCEL pad and contact an authorized servicer.
I have the same problem with GE TrueTemp Double Oven. I cut electricity during the self-cleaning mode, when I turned power back on, I got F8 Code, and the door is locked
