HP Compaq Presario SR2013WM (RE468AA#ABA) PC Desktop Logo
Posted on Sep 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Proccesor fan strts with high speed, nobooting
  • mp665447
    mp665447 Sep 21, 2012
    no key board lights.power on -green remains on.yelow flases and goes off,screen is blank.
Anonymous
Level 2:
New Friend:
  • Expert 59 Answers
  • Posted on Sep 07, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
59
Questions
0
Helped
15760
Points
171
Visit http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07110&tmp_track_link=ot_recdoc/c00007682/en_us/bph07110/loc:1&cc=us&dlc=en&lc=en&product=3300335
Load bios defaults by pressing F5.
This should resolve the issue else check hardware connections and explain what happens you press POWER ON button (along with light indications)
2answers
Where is the cooling fan switch on 2007 cadillac dts
No switch - the radiator cooling fans are controlled by the PCM which receives a signal from the coolant temperature sensor located at the passenger side end of the engine at the lower right.
2answers
I have a 2006 buick lucerne 3.8 v6 cxl.my coolinf fans dont come on .i need to know how to change the relay and the fuse.
Your vehicle cooling fan's are controlled by three relay's , couple of fuse's an the PCM - engine computer . The engine coolant temp. sensor is a input to the PCM , when engine temp get's to 212 the PCM will turn on the cooling fans in low speed . Checking to see what the actual temp is with a scan tool an a infrared thermometer at the thermostat housing ,an looking up the specification's in a service repair manual is how to diagnose . Not guessing an replacing parts . Plus learning how the cooling fan's work .
Relay Driven Dual Cooling Fan Diagnostics Reading factory service info as to how they work also would be a good idea .
Cooling Fan Control - Two Fan System
The engine cooling fan system consists of 2 puller type electrical cooling fans and 3 fan relays. The relays are arranged in a series parallel (S/P) configuration that allows the engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block. The ground path is provided at G104.
During low speed operation, the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan S/P relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the ECM supplies a ground path for the high speed fan relay and the cooling fan S/P relay through the high speed cooling fan relay control circuit. This energizes the cooling fan S/P relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time, the high speed fan relay coil is energized closing the relay contacts, and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit, to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
The ECM commands the low speed cooling fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 94.5°C (202°F).
• A/C refrigerant pressure exceeds 1447 kPa (210 psi).
• After the vehicle is shut OFF, if the engine coolant temperature at key-off is greater than 101°C (214°F), the low speed fans will run for a minimum of 60 seconds. After 60 seconds, if the coolant temperature drops below 101°C (214°F), the fans will shut OFF. The fans will automatically shut OFF after 3 minutes, regardless of coolant temperature.
The ECM commands the high speed fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 104.25°C (220°F).
• A/C refrigerant pressure exceeds approximately 1824 kPa (265 psi).
• When certain DTCs set
At idle and very low vehicle speeds the cooling fans are only allowed to increase in speed, if required. This ensures idle stability by preventing the fans from cycling between high and low speed.
Fan is not working on 2001 Chevy Silverado 2500 truck radiator fan motor?
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan s/p relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the high speed fan relay and the cooling fan s/p relay through the high speed cooling fan relay control circuit. This energizes the cooling fan s/p relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the high speed fan relay coil is energized closing the relay contacts and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Your best bet would be to take your vehicle to a qualified repair shop !
1helpful
3 speed fan barely changes speed
You are talking about your blower fan for the air conditioner and heater right? More information will be needed to solve the problem.
When you say it barely changes speeds, does that mean it doesnt speed up, or doesnt slow down? By that I mean, is it "stuck" on low, or high?
Most blower fans run at different speeds through the use of a multi-stage resistor built into the fan switch circuit. Low speed is a high value resistor, medium speed is a low value one, and high speed is the fan running without any resistance.
If your fan is running on high and doesnt seem to want to run on lower speeds, the resistor pack may be failing. If the fan is running on low speed only, it may be that the fan itself is beginning to fail, or that the lubricant in it has gotten gummy.
1helpful
My ac is not working I have a Chevy Tahoe 2005 the fans won't turn on either .
Hi Maria , The A/C system wouldn't keep the fans from running but none working cooling fans will keep the A/C from working ! This is a fairly complex system if your not familiar with this sort of thing ! I will add the description from the factory service manual.
Do you have a check engine light lit ? The thing to do would have it check at the dealer or a ASE certified repair facility ! They could hook up a advanced scan tool an diagnose fairly quick ! Or you could find a wiring diagram an try testing with a volt meter yourself ! But watch yourself so you don't short out the PCM - engine computer !
My computer isnt turning on
Make sure the BIOS settings are correct for the microproc and also make sure the motherboard supports a dual core processor.
1998 dodge stratus bogs while accelerating
try putting some seafoam in the gas tank
2answers
Laptop shuts off randomly
Interesting, the new Acer Aspire 5315 from Wal-Mart's Friday sale a week ago exhibits the same problem. I suspect it's a bad temperature sensor diode on the motherboard, or a faulty self-healing fuse. Otherwise, it could be a BIOS defect, where the cooling fan is not running fast enough or often enough to cool the laptop.
Cpu overheating
It is possible that dust got lodged into the fan bearing area. Remove the fan again and inspect the area where the fan spins with a magnifying glass. You may need to use compressed air to get the dust out. This may be followed by lubricating it with special oil or grease.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
