I am trying to update the firmware on my Cisco SPA504G, but I get a message saying my laptop cannot connect to the SPA phone. I already entered my IP address, and it still cannot connect.
You need to make sure that your laptop and IP phone are on the same network subnet. For instance, if you IP phone's IP address is 192.168.2.24 than your laptop must be on the same network addressing scheme, such as 192.168.2.23.
<a rel='nofollow' href="http://www.ciscopowercube.com">Cisco CP-PWR-CUBE3</a>
SOURCE: Ethernet Disconnected message in POE 7941G IP Phones
the first problem will be to check or replace the cable that you use to connect the phone or check the jack that you use
SOURCE: IP 7920 & Asterisk
I believe I saw somewhere that the 7920 works best with the 4.02 version of firmware... only hitch is you can't get it unless you have a valid Cisco login with access to their voice stuff. You could see if your local partner could get it for you otherwise. Also, I think you need the cradle to upgrade the phone manually - otherwise you need a TFTP server set up and the proper keywords in the cnf.xml file. There is better info on voip-info.org about these sccp phones - god I wish they (Cisco) would release a SIP firmware for these things!
SOURCE: Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
Complete these steps:
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
SOURCE: Cisco 7911G definitely dead?
You are very close to fixing your problem. You will need the correct firmware and files; these are proprietary but you should be able to acquire them from your certified reseller. Alternatively, here at IdacomUSA, we have the proper firmware on hand, and can flash the phone for you to get it back to life. Call us at 1-800-903-9190 or visit us at http://idacomusa.com
