Sir, i have samsung gt e3213k mobile phone, which is dual camera and 3g supported set. i did internet from my phone with data cable many days.suddenly its shows auto charging all time. i give it for repair the problem solve. i change the phone power socket which is inserted into adapter's other end.now my mobile shows a peculier problem. it shows a false charging if the phone is off or on. when i insert the adapter it shows charging on or off state. after 12-13 hrs its charging when i unplug the adapter it shows low battery. i checked the battery, adapter all is good. what is the solution to come out from the problem. the culprit is charging ic or someone else. please advice me what to do. my phone is totally useless now. i locate for samsung gt e3213k mobile phone charging IC , but unable to find it. please help me sir.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
SOURCE: i have samsung gt 3310i
i am purchase a samsang 3310i mobile but pc kies not available in net so i am not connecting computer internet via mobile
please guide me
SOURCE: NOKIA 5310 not charging
Eventually the problem was internal hardware, the charging terminals has a problem and that's why you getting this error on your unit while you try to charge your cellphone,
You have an alternative to use a desktop charger in able to charge the battery, or you may bring the unit for repair.
Hope this helps
SOURCE: Sir, Whan i am installing usb
you need to remove all of your phone locks you can unlock your mobile phone by entering this security code the default security code for nokia is 12345. turn off every lock that is enabled in your phone. then connect your phone with pc. now it works.
