You put the pod in and it punches it ok. Then there is a load of steam and noise and the coffee comes out ok into the cup. There is a load more steam and noise and then a tiny dribble of water ( even though the water tank is full). After a couple more dribbles, the button then goes onto the green light for you to press for more water - you can do this to get a cup but have to keep it held down for hours to get the amount that always used to come out on its own.
SOURCE: Tassimo - Can other pods be used?
I am not sure if you have a TARGET store near you, but I found some different Tassimo products there this past weekend.
SOURCE: plugged in, outlet ok, heating water, but no lights, press button - nothing
Try this. Worked for me!
http://rapidshare.com/files/238159116/Braun_Tassimo_3107_Disassembly.pdf.html?killcode=397312781122638452
SOURCE: Braun Coffee Maker Type 4093
it sounds like the hole at the bottom of the waqter tank is clogged. the fact that it is hot means the electrical parts are all working.
it should be an easy fix
SOURCE: the tassimo coffee maker does not heat up the
Take the machine back for warranty replacement.
SOURCE: Tassimo Coffee Maker: Tell me
• All lights will blink the first time you turn on your
machine. This is your cue to prepare your machine for use by
following the quick instructions in Step 1 on separate insert.
• If the water level runs low while you are preparing a
beverage, all lights will flash. Simply remove and refill the
water container, and brewing will continue automatically
where it left off. It should not be necessary to discard the T-DISC
and start over.
• The AUTO light will blink throughout the brewing process.
Some drinks require a pause in brewing as part of the recipe
for brewing your perfect cup - this is to allow the optimal flavors
to unfold and is a normal part of the brewing process. The AUTO
light will continue to blink throughout this process.
HOW TO MAKE A DRINK
• Place the mug of your choice on the cup stand.
• When the STANDBY light illuminates, insert the T-DISC® of your choice
and close the clamp.
• The HEATING light will blink as the brewer heats the water to the
optimal temperature for your drink.
• Once the proper temperature is reached, the AUTO light will
illuminate. When it lights up, press the start/stop button to begin
the brew cycle.
• The AUTO light will continue to flash throughout the brewing cycle.
PLEASE NOTE: Some beverages have a pause in brewing
after the initial influx of water into the T-DISC®.
• The MANUAL light will illuminate when your drink is ready.
