How i turn on the answering machine
SOURCE: How to change the answering maching message
Depending on how your automated attendant is programmed, you will need to either change certain prompts or certain Custom Service menu greetings. Without knowing how your system is configured, I can't be more detailed, sorry. However, we can fix this for you over the Internet with our remote support package...
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
SOURCE: number of rings on answering machine Panasonic KX TCM 506 BX
http://service.us.panasonic.com/OPERMANPDF/KXTG5631.PDF
this link will take you straight to the operating manual in pdf format
hope this helps you out
SOURCE: Panasonic phone KX-TG2740: instructions
I downloaded the instruction manual, based on someone else's solution to a different question about the same product.
SOURCE: Need instructions for setting up
For the manual, go here =>
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/DECT-6-0-Phones/model.KX-TG9343T
For the accessories, go to the same link above.
Click on Parts and Accessories Tab.
Then scroll to the bottom and Click on Parts Link labeled "See Parts Available For This Model"
If the link does not work, start here =>
http://www2.panasonic.com/consumer-electronics/support/Operating-Instructions
SOURCE: How do I retrieve messages on the Panasonic KX-T7030 phone?
By default, three options are enabled:
option #1: leave a message
options #5: call the operator
option #6: return to top menu
Here are some other features you may need
