Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
Eric Posted on Sep 07, 2012
5 minute fan delay on raypak - Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
Heating unit is delayed when you turn the heater on. It takes atleast 15 minutes or more before it comes on. what could be the problem.
When you say "unit is delayed" are you saying the fan does not come on when you switch the unit on, or that the air blowing takes 15 mins to get hot?
1helpful
Does the exhaunst fan turn on automatically when we cook or warm food items in our Samsung Microwave -- SMH 9187W?
Some interesting reading on page 8 of the owner's manual:
"Boilovers cause smoking and greasy spillovers that may ignite and spread if the vent fan is operating.To minimize automatic fan operation, use adequate sized cookware and use high heat on surface units only when necessary."
And on page 20:
"If the temperature becomes too hot around the microwave oven, the fan in the vent hood will automatically turn on at the LEVEL 2 setting to cool the oven. The fan will automatically turn off when the oven has cooled down sufficiently. This is an automated process and cannot be turned off. The fan may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. The Vent Fan will only operate in 1~4 levels modes while the microwave is working."
"Using the Vent delay off button
1. Press the Delay Off button once to turn the fan off after 1 minute.
2. Press the Delay Off button twice to turn the fan off after 3 minutes.
3. Press the Delay Off button three times to turn the fan off after 5 minutes.
4. Press the Delay Off button fiour times to turn the fan off after 10 minutes.
5. Press the Delay Off button five times to turn the fan off after 30 minutes."
If for some reason you don't have your owner's manual, you can still download it free here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
1helpful
Fan in main oven does not come on when oven is switched on,there is a delay of sometimes up to fifteen minutes oven has often reached desired temp from element at back of oven without fan operating. When ...
The fan motor is obviously faulty, the only real solution is to fit a new fan, if you do not, then the element is in danger of burning out, do not delay replacing the fan motor.
Top Raypak Pool & Spa Experts
Paul Carew
john h
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
