Onthejob5130 is right, the machine use E23 too tell you that the pump is obstructed.
before buying anythings, you have too check the manual too see if you didn't put it in factory test mode by accident. the manual is suppose to be under the top,(two screws on the back)
After that, second thing you have too do, remove the back (six screws) the drain pump is located under the the baril. there is a black rubber tube attached to it. In this tube, there is a basket that keed hard thing away from the pump. In my case, some hair pin pass the basket and block the pump rotor. The computer of the machine told me it was Error E23 but after cleaning, everything work like new!!
So try cleaning it yourself, it is easy even with basic skill. You will need a star screwdriver, a scare-screw driver, pliers.
Remember, better have the machine empty before doing anything, because you'll be working on the DRAIN LINE.
Hope that help someone.
Vincent D.
Hello
Welcome to Fixya
My name is Huum,
E23 means
Drain pump relay on the control board fails.
Take off the panel and clean the pump filter
Change control board or fix wire!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Take toe panel off unit than empty your pump filter...
Hello Robert Reische, thank you for your inquiry!
I understand that your Frigidaire washer is showing an "E23" error code. Based off the information I show "E23" stands for drain pump relay on board failed or wire off the pump. Which means you could have an issue within the main control board or wiring to pump. Since it could be any one of these underlying issues I would recommend having a technician come out to properly diagnose and repair your appliance. Hopefully this helps. -Matt
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Hello leah_mcmunn - the error code E-20 indicates that the water doesn't drain. This could be caused by either the drain hose is kinked or your household drain is clogged. If the drain pump is making a humming noise, check the restriction in the drain line. If not, then you might need to contact a professional to possibly replace the pump.
Hello
Welcome to Fixya
My name is Huum,
E23 means
Is this problem the upper main control board or the lower motor control board? If it's the lower how in the heck to you get it out?
