G31TMP21 Windows 7 pro
If someone need windows 7 key that i suggest you go site www.zescode.com to got. My key got here and after i used is great works. Hope can help you.
Most likely thinks your version is a clone. I kept having this happen to me with a new computer I bought with Vista on it. After a week I got fed up of it and demanded my money back at the store where I bought it.
SOURCE: Reset Admin Password on used computer.
If u want to reset admin password withuout lose nothing download this program burn it to cd and start pc from CD-ROM.It is veru easy way
Download
http://rapidshare.com/files/73232969/ERD_Commander_2007.exe
SOURCE: I lost my product key(certificate
If you can still boot into the operating system you can use jellybean keyfinder to find the key. Download jellybean from this link.
SOURCE: How do i backup my windows xp pro on my transcend storejet 320 gb
When you plug the Storejet into your USB port on your PC, after the PC's finishing installing the driver, you should see a new drive letter in your "My Computer" area. Once this is confirmed, go to your Start menu at the bottom left of your desktop, go to Programs, then Accessories, then System Tools, then Backup. The backup wizard will walk you through backing up your PC, and will ask you where to back up before it begins, Browse to the Storejet's drive letter, then backup. I hope this helps.
SOURCE: I have the same problem with dual boot Windows 7 and XP Pro
Boot.ini is a hidden system file. To edit it you will need to 'see' it. Open Windows Explorer and go to the local disk C:. Click on Tools and then on Folder Options. Click on View in the next window and scroll down until you find 'View hidden system files' and mark that. Close the windows until you are back the the view of C:. You should be able to see boot.ini. If not, press F5 to refresh the screen. Right click on boot.ini and choose Open. Make the modification you want and the save and close the file. When you have finished, repeat the step above and clear the mark to view the hidden files. That will help prevent system files from accidentally being deleted.
Good luck and please let me know how it works out for you. ~ Spoem
