Drain valve is open & no water coming out . What else can i do to drain water from tank?
Copy following link.
http://waterheatertimer.org/Water-heater-will-not-drain.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
This link was awsome! http://waterheatertimer.org/Water-heater... Had several ways to fix water heater problems. solved my problem completely
SOURCE: dripping from drain spout
If you are refering to the "Dripping coming from the preasure tempature valve,Then just turn off the valve where the water goes into the heater and open the P/T valve with a bucket below it draining only emought water to get below the level where it reaches. Normally the drain valves are plastic with a Male hosebib attached. Attach a garden hose to the rain and run it out to a point lower that the vaslve in order for gravity to drain the tank.The valve opens counter clock wise. If the valve is stuck or does not drain,and you have a foor drain handy,remove the whole valve and replace it with a boiler drain valve. If The tank is located below the drain level then you will have to either pump or carry the drain water to the higher level. Replace the P/T valve and reinstall the associated associated piping. I would use tefelon tape on the P/T pipe theads. You may have to open a hot water faucet in order for the air to replace the water in the tank ,in order to drain.
SOURCE: Drain Valve on bottom of water heater drips when Water IN turned
If the hot water heater is gas be sure it's turned off same if it's electric so you don't burn out theelements in the tank, I would advise you to buy some plumbers putty and pull the drain scre out and put putty in it then reinstall the screw. all the ones I looked at I could not tell by looking to see where the drain was and if it has like a hose bib on it or not. also pull the screw all theway out and see if you got some sand in the valve and if so use some compressed air in a can to blow the stuff out of the seating area of the screw. Hope this is helpful would be nice to have a picture of the drain.
SOURCE: Dripping Drain valve on rheem water heater
If your water heater is 10 years old or more, it's much better to replace the entire thing before you start having additional problems with it. You MAY be able to drain your water heater and replace the valve with something more reliable, but, as I've said... if your water heater is old, this is just the 1st thing to go wrong. More will follow.
