What are you plugging your 2 RCA connectors (from the headphones) into on the television?
You are correct, usually:
White = Left
Red = Right
In this case
Black = Left
Red = Right
Not sure....guess some manufacturers
need to be different...
Back to the issue,
You to need to connect the Black to White and Red to Red to the TV BUT you need to make sure you are connecting to an OUTPUT and not to an INPUT on the TV. Most newer TV's do have an "audio out RCA jacks" on the TV but not all. It should be labeled at the connector if it is an output, or just another input. You can always consult the TV manual to be sure.
Few things you can do to test
- Does your TV have a "headphone jack", use the adapter (2 RCA female - 3.5mm connector) to plug into the headphone jack and see if there is sound
- Connect the Black and Red RCAs from the headphones directly to the another output, like a DVD player, CD Player etc....
I hope this helps,
Magoo
